Carlos Souza
Feb 22, 2026 10:27 AM UTC
Github push não aparece
Estou tentando dar um PUSH em meus arquivos do Figma Make para o Github, mas não aparece a opção push to… (conforme as documentações). Já desconectei e conectei novamente a conta e repositório do Github 3 vezes.
As únicas opções que aparecem são: manage Github (direciona para a página do Github) ou Create Repository que mesmo criando um do zero, dá erro.
Feb 27, 2026 8:19 PM UTC
Hi ​@Carlos Souza, thanks for reaching out!
I do not speak Portuguese, so I hope it is ok that I reply in English. That said, is this your first time attempting to push from your Figma Make file to GitHub?
If so, please note that for the first time you're pushing from Make to GitHub, you must select Create Repository, enter a name for your repository, and click Create. It’s only after you’ve created a repository that Figma Make knows to push the same repository it created for your file. From there, each subsequent time you want to push to GitHub, you’ll see in the  Make settings menu, select GitHub > Push to.
Hope this helps explain! More information is available in our Help Center article here: https://help.figma.com/hc/en-us/articles/35463818346647-Push-from-Figma-Make-to-GitHub#h_01K7GPNZVXPBPV03VQS24JQGHD
