Imtiyaz_Ahmed
Nov 16, 2025 7:56 AM UTC
Github Push is not working in Figma Make
Hey,
Till yesterday Github Push was working fine in Figma Make. Just now when I tried to push the new changes, its showing me a “Failed” error. So I disconnected and tried to create a new repository, but its showing an error again - “Failed to create repository”
Could you please let me know whats the issue? and pass this to the team?
ITS KINDA URGENT
UPDATE:
The repo is being created but its not getting connected. When I try to create a new repo, I still get the same error but when I check my GITHUB, the repo seems to have been created
Celine_Solution
Nov 19, 2025 9:53 AM UTC
Hey ​@Imtiyaz_Ahmed , I see with the internal team that they were able to fix your issue and the feature is working as expected now.
I’ve gone ahead and marked as solved and close the topic here. Thank you!
Imtiyaz_Ahmed
Nov 16, 2025 8:05 AM UTC
​@Celine_ Kindly, help out! Its high priority
Imtiyaz_Ahmed
Nov 16, 2025 8:14 AM UTC
UPDATE:
The Github push is working with other files. Its not working with anything that has Supabase connected. The issue might be the following :
This file contains a JWT token that GitHub's security scanning flags and blocks from being pushed.
 How to overcome this?
Imtiyaz_Ahmed
Nov 16, 2025 8:23 AM UTC
UPDATE:
Tried creating a repo and pushing updates with another file that has supabase connected, it worked there. Something is wrong with this particular file.
Even after I tried duplicating this file and testing it again, GITHUB push did not work. It is always successfully creating GitHub Repo but showing error on Figma Make Side
Nov 17, 2025 12:47 PM UTC
Hey ​@Imtiyaz_Ahmed , thanks for reaching out in the Forum and for flagging this!
This does look unexpected, and I’d like our support team to take a closer look.
When you have a moment, please reach out directly through our bug report form: Submit a bug report.
When filling it out, use the same email connected to your Figma account, and include the steps you’ve already tried, along with any error messages, screenshots, or a quick screen recording. This will help the team to better visualise and understand the issue more clearly. Thank you!
Imtiyaz_Ahmed
Nov 18, 2025 3:07 PM UTC
​@Celine_ Hey celine,
Thank you alot for responding so quickly. I have followed the steps you adviced and add a bug report. Hope this gets solved quickly.
Celine_Solution
