Ana Cornejo
Jan 12, 2026 8:32 AM UTC
GitHub integration not working
Hi there, I have spent an enormous amount of time building the UI of a mobile APP with Figma Make.
I have purchased the full seat plan with the only objective to be able to push the code to GitHub, but it's showing an error that just stays "can't create repository" The solution Figma Make is giving me is to manually copy , paste and recreate all the project structure manually locally, this is not acceptable.
The project i have is working correctly, I converted it to react native environment but urgently need to push it to a repository to keep working on it locally from the code.
Ticket created: 1681642
Urgency: HIGH
Note: The repo is created but it does not push anything to it.
Jan 12, 2026 1:26 PM UTC
Hi there, thanks for reaching out and for clearly explaining the situation. I understand how blocking this is, especially given the time you’ve invested and the urgency around pushing your code to GitHub.
I can see your support ticket (#1681642) and have escalated this internally so the team can take a closer look at the issue with repository creation and pushing from Figma Make.
In the meantime, please make sure you’ve followed the steps outlined in our Help Center article for setting up the Push from Figma Make to GitHub integration.
Thanks for your patience while this is being investigated. Someone from our support team will follow up with you as soon as possible with next steps or an update!
Update: Our Technical Quality team is waiting your response for further investigation. Please check your inbox when you can, thank you!
