Yehor Korniienko
Jul 23, 2025 9:26 AM UTC
get_code method on MCP server does not return expected results for Android (Jetpack Compose)
I’m sending a get_code request to the Figma MCP server via Cursor AI.
Here is the request body I’m using:
{ "nodeId": "XXXX:XXXX", "clientLanguages": "kotlin", "clientFrameworks": "android,compose", "clientName": "cursor" }
However, the response I receive is in JSX (JavaScript XML) format with Tailwind CSS classes, not Kotlin.
I would expect either Kotlin code (Jetpack Compose) or at least a clean JSON representation of the selected frame.
Question:
How can I retrieve Kotlin code or a raw JSON object for the selected frame?
Adam_Butterfield
Dec 16, 2025 5:35 AM UTC
Just figured out our iOS issue. We were publishing with the wrong label….
Now using “SwiftUI” as label, MCP is returning the correct code after setting language preference to iOS/SwiftUI. Seems like the label we publish with needs to match the language preference labels in Figma.
Would also be really nice if this was documented as well.
