Eugene_Simonov
Feb 9, 2026 3:35 PM UTC
Gemini 3 Pro with Nano Banana — “model currently overloaded” in most generation attempts
Hi everyone,
I’m experiencing a persistent issue when trying to use Gemini 3 Pro with Nano Banana in Figma AI.
In about 90% of my attempts to generate or regenerate an image, I receive the message:
“model currently overloaded, try again later.”
This started roughly a week ago, and since then the model has become almost unusable for me — most requests fail with this error. Retrying multiple times usually doesn’t help. Other models work correctly, иut the result, of course, is not as good.
Feb 12, 2026 1:07 AM UTC
Hi ​@Eugene_Simonov,
I understand that you’re experiencing the “model currently overloaded, try again later.” error when using Gemini 3 Pro.
Thanks for flagging this. I’ve passed this along to our team internally.
In the meantime, while you mentioned that the results may not fully meet your expectations, you could try switching to Gemini 2.5 or GPT 1.5 as an alternative.
Eugene_Simonov
Feb 12, 2026 10:57 AM UTC
Thank you ​@Junko3  for your quick response!
Let me know if you need any additional information from me.
Yes, of course, I am now trying to use Gemini 2.5 or GPT 1.5 more often, but of course, I would like Gemini 3 to work as before, because the results were often very successful.
In any case, thank you for bringing this to attention and trying to resolve the issue.
Web-designer CS
Feb 18, 2026 2:01 PM UTC
I wanted to report that I am facing the exact same problem described here. I encounter these overload errors with both Gemini 2.5 and 3.0 models. Switching to other models isn't a viable solution for me as they don't fit my specific workflow requirements. My colleagues are also affected by this same issue.
xflee
Feb 19, 2026 11:27 AM UTC
This problem has been going on for a long time. I have a Google subscription, but I find it easier to work in Figma. Is it possible to implement the ability to use nanabanana's own APIs?
Sergey Osipov
Feb 19, 2026 2:56 PM UTC
Hey everyone! I have same problem
Feb 19, 2026 7:03 PM UTC
Hey All, thank you for continuing to flag this issue!
Our team is aware of this ongoing issue with Gemini 3 Pro with Nano Banana. To be completely transparent, there has been a significant number of reliability issues with it this month, and it’s been determined as a Google issue that we cannot control. As a temporary solution, the team encourages you to use Gemini 2.5 or GPT 1.5 instead.
We’ll continue to pass your feedback onto the team and will provide any updates addressing the Gemini 3 Pro with Nano Banana issues, when/if we hear more directly from the team.
Aldrei
Feb 26, 2026 1:40 AM UTC
It’s been two days. Is there an update or fix to this issue?
Eugene_Simonov
Feb 26, 2026 9:14 AM UTC
Yes, I have the same problem. Now Gemini 3 Pro hasn't been working at all for several days.
Feb 26, 2026 1:19 PM UTC
Hi ​@Aldrei and ​@Eugene_Simonov, thanks for following up!
I completely understand how this must be affecting your workflow, but as I mentioned above, this is a Google issue with Gemini 3 Pro with Nano Banana that our team cannot control at this point, which is why it is now unavailable for use. As a temporary solution, please try using Gemini 2.5 or GPT 1.5 instead.
Hope this helps clarify. I’ll be sure to provide an update from the team as soon as we know more about the ongoing Google issue.
Web-designer CS
Mar 5, 2026 3:27 PM UTC
Hi,
Thank you for the explanation regarding the Google issue.
However, this raises a serious concern. If the feature was known to be problematic or unavailable, why were credits still being deducted for failed attempts? I was not aware of this issue, so I kept trying to generate images, resulting in all my credits being wasted without a single successful generation.
Furthermore, I tried the alternative models you suggested (Gemini 2.5 and GPT 1.5), but they are not working either — they also deduct credits but fail to produce any images.
How am I supposed to get these credits back now? What solution do you propose for this problem?
