Hey @Becca7, thanks for reaching out!
To edit a file on a paid plan, someone needs both a seat that includes the product (a Full seat for Figma Design) and ‘can edit’ access to that file or folder. Since your teammate has to request edit access on files they haven’t worked in, permissions look like the most likely cause.
On the Professional plan, joining the plan doesn’t give someone access to your folders and files on its own. New members need to either be invited directly to the folders and files they work in, or be covered by the sharing settings on those folders and files.
Here’s how to find where the gap is.
- Open a folder or file they have to request access on, and click Share to open the share modal.
- Check the first row under the invite field, which shows who has access across your plan. If it isn’t set to can edit for everyone in your plan, that could explain the request prompt.
- Look for your teammate in the list of people below. If they aren’t listed, they haven’t been invited directly and are reaching it through the sharing settings or access inherited from the folder.
- To fix it, you can invite them directly to the folder with can edit, and their access will pass down to everything inside it. You can also change who has access on the folder and its files. Each file has its own sharing settings, so changing the folder alone may not cover every file. The owner, anyone with can edit access, or an admin can make these changes.
If you’re adding them to several folders, you can nest those folders inside one parent folder and invite them to the parent instead.
You can find more details in our Help Center articles.
Hope this helps and let me know if you run into any issues, happy to help further!
