Aventure Agency
Dec 26, 2025 8:06 PM UTC
Frustration when trying to integrate Figma Make with a minimally acceptable Supabase database.
It's very frustrating to realize that Figma Make can't perform a simple login/registration authentication using SQL in SupaBase. I've been stuck in error loops for 3 days.
Figma make is really limited to being an advanced prototyping tool.
Perhaps I confused it with the same proposal as Lovable, v0, Replit, and other Vibe Coding tools.
Dec 29, 2025 11:52 AM UTC
Hi Aventure Agency, thanks for reaching out to the Figma Forum and sharing the context here.
To start, could you please make sure you’re following the steps outlined in this guide to connect Figma Make with Supabase: Add a backend to a functional prototype or web app. If you haven’t already, I’d also recommend disconnecting Supabase and then reconnecting it to see whether the issue persists.
If you’re still running into the same authentication or error loop after trying that, our support team can take a closer look at your specific file and setup to understand what’s going on.
I’ve sent you a DM with some important information so you can share the details securely via a form and the team can investigate further. Thank you!
Jason D
Jan 19, 2026 8:06 PM UTC
This might be anecdotal but I was able to do this immediately without issue in Figma Make with Supabase integrations. Very handy in fact
