Andyrrrrrrr
Oct 23, 2026 6:23 PM UTC
Frames converted to slots don’t show up in downstream instances after publishing
I’m working with a library built before slots existed. Like many older libraries, its components use the old pattern: a frame preloaded with component instances, most of them hidden.
For example, a select menu component holds a stack of select-row instances, most of them hidden.
I converted the frame that holds the rows into a slot so the rows can be edited freely downstream. After I publish, the slot doesn’t appear in downstream files. This happens with existing instances and with freshly inserted ones. The freshly-inserted instance just continues to show the old non-slot build, no matter what I do.
Strangely, if I copy the menu component with the slot directly from the library file, then paste it in a downstream file, I can see and use the slot, but pulling updates from the library file converts it back to the pre-slot construction and wipes my overrides.
  • Is this expected behavior when converting an existing frame to a slot?
  • Is there a workaround, or do I need to rebuild these components with slots from scratch?
Thanks!
Andyrrrrrrr
AndyrrrrrrrSolution
Oct 25, 2026 10:56 PM UTC
Thanks for your reply ​@adamsmasher.
The parent component I’m attempting to convert to use a slot is in a separate library file. I am publishing the library file and accepting updates to it in the downstream one, but no luck. The updated file refuses to recognize the converted frame that should now be a slot.
I do have lots of existing instances in the downstream file with overrides, but as you mentioned, even fresh instances won’t show the new slot, so I haven’t spent much time worrying about that.
What I ended up doing was:
  • Add a new, empty slot to the parent container
  • Turn it off by default behind a variable
  • Publish the component
  • Accept the update in the downstream file
  • New instances now let me see that added slot
It’s a little bit fiddly and leaves more layers floating around than I’d like, but it at least lets me use slots in the existing downstream components.
adamsmasher
Oct 24, 2026 7:07 PM UTC
Hey ​@Andyrrrrrrr! Thanks for your post - what you’re looking to do is a supported change, so I can see why you might be perplexed by the lack of changes in instances.
Did you override anything in any of the instances that don’t reflect the slots change? That would prevent automatic propagation since it would wipe out those overrides. Having said that, it doesn’t explain what you see when you insert a fresh instance.
Is the updated component in the same file as your instances or in a different file?
Andyrrrrrrr
AndyrrrrrrrAuthorSolution
adamsmasher
Oct 28, 2026 7:44 PM UTC
Thanks for sharing those steps, ​@Andyrrrrrrr - since you provided that in your reply I marked is as a solution for anyone who encounters this issue. Let me know if you see this with other components, or even with a newly made component - happy to help bring this to the support team for deep investigation if needed.
