Yanny Cheng
Apr 13, 2026 4:19 PM UTC
Font weight mismatch after editing text
We’re using variables for all font styles with Red Hat Text and noticed an issue with font weight, “Medium” particularly. When we double click and edit a text field, the font weight visually changes, but it still shows as “medium” in Figma. This doesn’t only happen to my file but everyone else shared the same set design system in our organization.
I’m not sure if this is due to the installed font or a figma display issue. In the screenshot, “Gross sales” shows the updated (incorrect) appearance after editing, while “Deposit amount” reflects the original expected style.
Does anyone has the same issue or has any idea why this happen? Thank you.
AskDave
Apr 14, 2026 10:49 AM UTC
Hi Yanny,
Dave here from Figma’s community support team 😊
Thanks for taking the time to share this, I can imagine how confusing it is when the text suddenly looks off even though nothing seems to have changed on the surface.
What you’re seeing is usually down to conflicting font versions rather than the variable itself. Even though Figma still shows “Medium”, the rendering can shift after editing if different editors (or your org) are using slightly different versions of the same font.
A couple of things worth checking:
  • Make sure everyone is using the exact same version of Red Hat Text
  • If the font is both installed locally and uploaded to your org, that can sometimes cause conflicts
  • Figma will prioritise org fonts over local ones, so it helps to standardise on one source
To fix existing text layers, you can try:
  • Select the affected text
  • Run “Recompute text layout” (via quick actions)
If it’s happening across multiple files, the cleanest fix is:
  • Uninstall the font from all machines
  • Reinstall the same version from a single source
  • Restart Figma
If it’s still happening after that, it’d be worth submitting a bug report with a file link so the team can take a closer look, to do this, visit our support hub
Renaynay
May 5, 2026 2:47 PM UTC
​@Yanny Cheng
We also use Red Hat Text as one of our variable text styles and noticed this issue recently.
It looks like the variability of the font disappeared for my team, and I’m trying to figure out what happened.
