Henrik Asteberg
Dec 2, 2025 12:50 PM UTC
Font size variable doesn't update when changing mode
I’m using variables for different parts of my text styles in order to create a multi-brand design system. An issue I’ve found is that when I change variable mode the text size doesn’t update, even though other variables update when I swith between the two brand modes. For example the font family is changing as intended, but not the size. However, if I select a component with the text style already in use and reselect the same text style then it updates itself to the correct size. What is causing this and is someone else experiencing this?
