AndrewG13
Feb 18, 2026 6:12 PM UTC
Fixing error loop.
Figma is stuck fixing an error. It shows "error", then fixes it, when testing it says error again for the same thing over and over. How do I get pass that?
    Gayani_S
    Feb 19, 2026 4:07 PM UTC
    Hey ​@AndrewG13, thanks for flagging this!
    Just to confirm, is this happening in Figma Make? If it’s happening in Figma design, could you let me know where you’re seeing the error? A short screen recording would be really helpful so we can understand what’s triggering the loop.
    If this is in Figma Make, here are a few recommendations to help resolve this:
    1. Ask Make to fix a specific error by copying the exact error message from the browser console and asking Make to investigate it.
      An example prompt would be: “I’m getting [this error - insert error message/ID] when trying to view this Make. Can you figure out why this is happening and how to fix it?”
    2. If the error started recently, revert to an earlier version of your Make and see if the issue still occurs. This can help narrow down what change introduced the issue.
    3. If the cause isn’t clear, prompt Make to add targeted console messages to help diagnose the issue.
    • Run the Make again and observe the new console output
    • Copy the console messages back into Make and ask it to continue debugging based on that information
    These back-and-forth often helps Make pinpoint the root cause and propose a fix.
    Hope this helps!
    AndrewG13
    AndrewG13Author
    Feb 21, 2026 2:44 PM UTC
    Hi,
    I just signed up with Figma and started using it. There is nowhere an indication of “Make” or “Design”. I don't know hoe to identify or differentiate.
    I tried your suggestions but nothing works. The issue arose from the first time i could test it so reverting wont help.
    Cant you log into my account and check?
    Regards
    Andre
    Gayani_S
    Feb 23, 2026 2:57 PM UTC
    Hey ​@AndrewG13, thanks for clarifying and sorry you’re running into this right from the start.
    Figma includes several products (Design, Dev Mode, FigJam, Slides, and Make), and the interface can look a little different depending on where you are. This Help Center article shows what each one looks like so you can compare with what you’re seeing: https://help.figma.com/hc/en-us/articles/14563969806359-What-is-Figma.
    For security and privacy reasons, I won’t be able to log into your account, but I definitely want to help you get unstuck.
    If you could share a short screen recording of what’s happening, that would really help me understand the loop and guide you properly.
    If possible, please include:
    • The full screen (so I can see where you are in Figma and which product you’re in)
    • The exact error message
    • What happens when you click “fix” and it loops again
    You can share a Loom link or upload a video via Google Drive. Appreciate your help!
