Henry Agnew
[Fixed] Figma sites: center-aligned frames not publishing correctly
  • May 24, 2025
  • 13 replies
  • 809 views
Hi! I first had this problem today, with designs that previously published correctly: center-aligned frames are publishing as left-aligned divs. See example below showing (top to bottom) 1) Previewing page within Figma Sites, 2) Autolayout settings, 3) Published page as displayed in Chrome
Best answer by y_toku
Hi all,
Thanks for your patience. Our engineering team has deployed a fix. The issue should now be resolved! Could you please try either reloading the file or restarting your Figma app?  Let us know if the issue persists.
Thanks again for flagging and your patience!
Toku
Bagas Al Haekal Nasution
I Have the same issues today
Jafari Mulla Ghany
I also just encountered this issue/bug, in the previous version it was still aligned center when published, but today when I did an update in the design and then published it again, it became aligned left even though the parent was already aligned center. Is this a bug that has not been solved or maybe there is already a solution?
PRyan
I Have the same issues today, Anyone has a solution?
M0rel
Same issue here.
On March 23rd, alignment in production was looking just the same as in Figma Sites. Two days later I published it again, just with content updates. Then all the Auto-layout containers, in all pages, were sticked to the left, regardless of changing them back and forth on Auto-layout settings.
Mihya
I also have the same issue. Last night, I spent quite a lot of time thinking I messed something up. I tried rebuilding the whole page section by section, and it worked at first but suddenly broke randomly and became unfixable.
prayminder
Same issue here, noticed today after publishing. It doesn’t happen for all frames, but I don’t see a pattern.
I also remember this happen once more some days ago, but it got fixed once I re-published. Unfortunately this doesn’t work now, I’ve re-published and it’s still broken.
Martin_Slovik
I have the same problem. It’s centered while I’m editing it, but when I publish it, it’s aligned to the left.
ana.bolio.ayora
May 26, 2025
Im having the same issues. Is there a fix? The prototype looks fine but when i publish, it aligned to the left, even if i align it to the right
Hi all,
Thanks for bringing this issue to our attention. Our team has already created an internal report about this, and I'll keep you updated once I have any information I can share.
Thanks your patience while we look into this!
Toku
robertlaskus
@y_toku any updates on this topic?
