richard10
Aug 15, 2024 7:29 AM UTC
FIX LAUNCHED: Issues renaming/highlighting text in the layers panel
I can rename a layer but I cant highlight parts of text when doing so.
Also usually when I click to a different layer, the rename is set… but now it stays editable until I press Esc
Happening across web and app.
djvSolution
Aug 16, 2024 8:11 PM UTC
Hey All, thanks again for your patience and understanding!
The team launched a fix for this bug. If you fully refresh Figma, things should now be working again as expected.
Knyaginin
Aug 15, 2024 8:21 AM UTC
Same issue. It’s problematic. Windows 11. Desktop APP.
Video: Monosnap
andrey.rublev
Aug 15, 2024 4:04 PM UTC
The main thing is not to open files from other accounts, this glitch is transmitted across accounts.
Aug 15, 2024 10:51 PM UTC
When I double click an item to rename, it stays highlighted. I can no longer click the mouse to the end or anywhere inside the name to edit. I can retype but then have to press ENTER to keep it. This used to work. It DOES work on the PAGES up top. The click/select mouse function works different on PAGES and LAYERS for some reason. This is a new thing. I closed out Figma and reopened but still does it. It does the same in other files.
/Desktop version
Aug 15, 2024 11:51 PM UTC
I have the same issue right now and only started a couple of hours ago… desktop version, windows 11.
Same as OP, I used to be able to ctrl + r the layer or double the layer name and click on the name again in order to select only a part of the name, but now I can only double click and when highlighted, my cursor does nothing when I click or click and drag.
Aug 15, 2024 11:52 PM UTC
This JUST started happening to me a few hours ago and its driving me NUTS.
I used to be able to ‘CTRL + R’ a layer name then double click in order to highlight only a part of the total layer name. Now I don’t even see the ’ I ’ cursor anymore and need to use the arrow keys in order to navigate through the name with the marker.
Aug 16, 2024 7:54 AM UTC
I have the same issue, Windows App. Started two days ago for me.
Ashzzz
Aug 16, 2024 7:55 AM UTC
Hi hi, I encounter an issue, I am not able to use touchpad or mouse to move cursor after clicking “Rename”, the all texts are be selected. I only can move cursor by keyboard “⬅️”“➡️”. I am not sure if it is a bug.
Does anyone have same issue? Or is there a way to fix this one? Please let me know if there is a such. All the best to everyone~
Sophie32
Aug 16, 2024 9:36 AM UTC
I have the exact same issue! only started yesterday and its super annoying!
DES_HuongDT26
Aug 16, 2024 9:37 AM UTC
Same here. It has happened since yesterday afternoon.
Yeah! How can that problem pop up while your working? It wasn’t an install that broke it. Such a weird one. How does it break on LAYERS only? Ugh…
