Alexandre_Shyjada1
Nov 26, 2025 1:45 PM UTC
Fix for the Variables panel behavior when pressing Esc while a secondary window is open.
The behavior when pressing “Esc” in the Variables panel is not working as expected. By default, whenever two or more windows are open, the last child window should be the first one to close when pressing Esc.
In the Variables panel, the behavior is reversed, and the parent window closes instead of the child window.
My suggestion is that, when a sub-window is open inside the Variables panel, pressing Esc multiple times should close each window in the correct hierarchical order.
Reported behavior:
Esc key behavior in the “Variables” panel
Expected behavior:
Esc key behavior in the “Styles” area
Wenzel
Apr 18, 2026 7:38 AM UTC
I agree, I accidentally close the variables window constantly while editing color variables. Its quite jarring how this one window behaves very differently from all the others. Additionally the “Toggle variables” menu item doesn’t even come with a keyboard shortcut assigned by default.
I’m used to pressing ESC to navigate backwards the path I came by closing one window at a time, however pressing ESC while editing a variable completely ends the entire workflow instead.
Wenzel
Apr 18, 2026 7:51 AM UTC
Seems adding a custom keyboard shortcut to Toggle Variables is also impossible. 😞 Figma appears not to respect shortcuts set up in System Settings and I can’t find a non-native way to add one inside Figma.
Yurii.Vovchuk
May 6, 2026 7:29 AM UTC
Also faced this frusrating behavior. Would be nice If you can close the Variables Panel with “esc” button only  when the Panel is in a focus.
