minhojk
Nov 8, 2026 8:39 AM UTC
FigmaAgent 126.10.13 memory retention: font lookup grows to 4.7 GiB
Hello Figma Support,
Please open a bug ticket and escalate a reproducible FigmaAgent memory-retention issue to the engineering team. During normal use, figma_agent reached about 4.7 GiB after running for over four days, and my 16 GiB Mac became very slow. Restarting the helper released the accumulated memory.
Environment
- Component: local font helper, executable figma_agent, bundle com.figma.agent
- macOS 27.0, build 26A5425a; Apple Silicon (arm64); 16 GiB RAM
- FigmaAgent 126.10.13, protocol version 24
- Installed Figma desktop app: 126.9.11; the desktop app was not running during the controlled reproduction
- Font cache: 3,973 font files, including 3,307 activated through SandollCloud
Controlled reproduction (no Figma document edits required)
1. Start FigmaAgent and measure its physical footprint.
2. Repeatedly issue this normal font-enumeration request:
   curl -s -H 'Origin: https://www.figma.com' http://127.0.0.1:44950/figma/font-files > /dev/null
3. Measure footprint and heap object counts again, then stop requests and leave the process idle.
Measured results
- In a 67-request run, physical footprint rose from 35.970 MiB to 129.798 MiB immediately after the requests.
- After 15 seconds idle it remained at 126.016 MiB.
- Heap growth across those 67 requests: +303,577 NSURL objects (exactly 4,531/request), +302,840 CFString objects (4,520/request), and +67 NSArray storage allocations (one/request).
- Repeated version queries and English/Korean spell-check requests did not show comparable linear growth.
macOS memory diagnostics
- 'leaks --autoreleasePools' reported about 89.8 MiB held directly or indirectly by autorelease pools.
- On long-lived Actix HTTP worker threads, the reference chain was autorelease pool -> __NSMallocBlock__ -> captured block -> captured NSArray -> NSArray storage -> NSURL / CFString. Individual retained font arrays were about 1.28 MiB.
- The ordinary leaks scan found only 3,536 bytes of unreachable leaks. The main problem therefore appears to be reachable objects retained in undrained worker-thread autorelease pools, rather than orphaned allocations.
This points to autorelease-pool lifetime management in the font-enumeration path. Please confirm the exact responsibility between FigmaAgent and CoreText on this macOS build; I have not established whether other macOS versions are affected.
For now, I have had to add a local workaround that restarts only FigmaAgent when its footprint stays above 256 MiB. This is not a fix and briefly interrupts local font access.
Please provide a ticket/bug ID, route the reproduction and retention chain to engineering, and advise which release will address it. Sanitized heap summaries and an autorelease-pool excerpt are available.
Thank you.
    Donkt
    DonktSolution
    Nov 8, 2026 11:24 AM UTC
    Hi ​@minhojk, thanks for posting!
    I’ve created a ticket with the ID #2250288 about this for you. Thank you for all of the detailed information you’ve shared here as well! I’ve made sure to share this post with the team who’ll be looking into this for you.
    If you have any more information please share it in a reply to the ticket.
    A member of the team will be in touch with you in the near future. If you need help with anything else in the meantime let us know!
    Donkt
    DonktSolution
