Faclon Design
Figma slots not adapting variable properties
Screen Recording
I designed ‘Navbar’ component with 2 variables (Default, Expanded), for Navbar body container applied slots. In this body container, I used one componet (Entity Tab) having variables default and expanded.
In Navbar (Default) body container varible used ‘Entity Tab’ default and in Navbar (Expanded)  used ‘Entity Tab’ expanded variables.
While switching between Navbar component, ‘Entity Tab’ (present within slot) properties not changing.
Gayani_S
Gayani_SSolution
Hey ​@Faclon Design, thanks for taking the time to explain your setup so clearly
I checked in with the team on this, and unfortunately what you’re running into is a current limitation in how slots work.
When you modify or place a component inside a slot, those layers essentially become detached from the original component structure. Because of that, any component properties tied to those layers, including variant-based changes like switching from Default to Expanded-won’t update as expected.
The team is aware of this limitation and is working on making this behaviour clearer.
Hope this helps!
Gayani_S
Gayani_SSolution
Hope this helps!
Levi Fink
​@Gayani_S
Is this intended behavior or will slots be updated to allow internal variant based changes possibly in the future?
It’d be amazing if components within slots could retain their interactivity in prototypes.
kenny_paramify
Please prioritize a fix. We committed to slots, potentially solves os much for us, but the limitation is hugely problematic for us, costing us so much time to fix prototypes.
mnorooz
I tried copying and pasting a component with a slot containing nested components, images, and text. When I paste it onto the canvas, it creates an exact clone. However, when I paste it to replace another component or into a variant set, everything resets to the default state instead of preserving the nested content. Components within a Slot will not preserve your overrides. This is incredibly inefficient.
thinh.nt
Same Problem! The Slot component issue is becoming a major pain point. Please prioritize a fix.
