Iasonas Georgiadis
May 29, 2026 9:19 AM UTC
Figma Slots Bug - Instances containing slot(s) don't receive the same updates as their main component
This bug appears to be unpredictable, which makes it difficult to understand the root cause.
I’ve created many components that contain one or more slots. However, when I make changes to the main component—such as updating colors, padding, borders, or other container-level styles—those changes are often not reflected in instances where the slot area has been configured.
I would consider this a bug because it’s essential for us to be able to update the main container around a slot. It makes sense that the slot content itself remains configurable and does not automatically inherit every styling change made after customization. However, the parent component (for example, a card container) should still receive updates from the main component.
What makes this particularly challenging is that the behavior is inconsistent. Some configured instances correctly receive the updates, while others do not. To clarify, I’m not referring to changes made within the slot content itself, but rather to updates applied outside the slot area on the main component.
Lara9
May 29, 2026 1:41 PM UTC
We have currently the same issue!
Jaycee Lewis
May 29, 2026 6:45 PM UTC
Hey ​@Iasonas Georgiadis 👋 Thanks for the clear write-up — the "some instances update, some don't" part helps narrow this down, so I appreciate you calling it out.
To dig into the inconsistency, a few things would help for you or ​@Lara9 (or both 😊):
  • A short, full-screen screen recording showing the main component edit and an instance that fails to pick it up. Seeing it happen is the fastest way for us to pin down the cause.
  • Are these components coming from a published library? When an update doesn't propagate, are you editing in the library file itself or in a file that uses it?
  • On an instance that doesn't update, click into it and check the right sidebar—is the whole slot showing as overridden, or just specific container properties?
That third point is worth noting — slot overrides can have a wider scope than expected, catching properties you think are outside the slot.
To test this:
  • Change a parent property like fill or corner radius on a fresh instance's main component
  • If it updates, configure the slot and change that property again
  • If it stops updating, the override scope is the culprit
Thanks for the additional information! — Jaycee
Iasonas Georgiadis
Jun 2, 2026 7:36 AM UTC
Hi Jaycee,
I’ve attached two videos for reference.
In the first video, you can see that configuration does not work correctly on a heavily configured component. In the second video, however, everything appears to work as expected—at least when creating a fresh instance and editing it directly.
This makes me wonder whether the issue is related to the complexity of the component configuration or if there is another limitation at play
Worth mentioning that everything seem to work smoothly at first for my heavily configured component as well, but then it suddenly lost its connection to the main.
I haven’t published these components yet. I’m working in the same file where they were created and I’m inserting them as instances within that same file.
For the case I’m exploring, it seems that the entire table component, including its slots, is marked as modified. In addition, the nested row instances that also contain slots are marked as modified as well.
I’d like to understand whether this is an inherent limitation of Slots or whether you agree that this is something that should be addressed.
From my perspective, this is clearly a bug. If we can’t support multi-level nested slots or basic component–instance relationships, it significantly undermines the value of using Slots in the first place.
If this behavior is expected, I’d appreciate a clearer understanding of the current limitations and your roadmap for improving Slots. I’m currently building a design system around them, and based on both my own experience and feedback from others in the community, relying on Slots in their current state appears to be a risky decision.
Could you share any plans or estimated timeframe for addressing these limitations and investing more in the Slots as a feature?
Thank you.
Jaycee Lewis
Jun 3, 2026 8:35 PM UTC
Hey, ​@Iasonas Georgiadis 👋 Thanks for the examples. I located your support ticket (ID 1939370) and see our team is taking a look. Please let me know if I can help you in any other way — Jaycee
Alain A.
Jun 16, 2026 6:18 AM UTC
The same issue. Child components with slots aren't updated when the parent component changes. It would be great if I could be notified as soon as this bug is fixed.
Iasonas Georgiadis
Jun 17, 2026 10:37 AM UTC
Hy Jaycee, this ticket is unrelated to the slots one, it was about a swapping instance issue on another level.
Jaycee Lewis
Jun 18, 2026 7:14 PM UTC
Hey, ​@Iasonas Georgiadis 👋 Thank you for (gently) letting me know I was mistaken in this case. I appreciate you. If this needs a separate support ticket, we can do that together. Since you already provided two videos and many details, I’ll get it opened and link the case number back here for you. Talk soon! — Jaycee
Iasonas Georgiadis
Jun 18, 2026 7:26 PM UTC
Thank you ​@Jaycee Lewis, I have already opened a ticket for this matter.
