mardeleons
Apr 27, 2026 6:31 PM UTC
[Figma Slides] Skip Slides have a rounded edge
Rounded corner
Hello, I am not sure if this is intentional or not. Hidden/skip slides now have this oval fillet in the corners.
Jaycee Lewis
Apr 27, 2026 8:18 PM UTC
Hey, ​@mardeleons 👋 Thanks for your post. Can you tell me a bit more about this issue, please?
  • Where is this happening? For example, I found a similar thread where this was happening while exporting Slides as a PDF
  • Can you reproduce this when creating a few default slides? I’d like to set up my test the same way you are doing it
Thanks! — Jaycee
mardeleons
Apr 27, 2026 8:25 PM UTC
Hi  ​@Jaycee Lewis,
yes it happens also when i create a new slides from a new default template.
Below is a step by step from a new figma slide → template → Skip Slide.
Let me know if you need any more information to recreate the problem for your testing!
Thank you,
Martin
de_la_Puente_Pantoja_Alberto
Apr 29, 2026 8:27 PM UTC
Hello, same bug here. It happens in all of our files.
mardeleons
May 3, 2026 8:26 PM UTC
The problem is fixed.
The slides no longer have a corner issue when the slides are “skip” mode.
Thank you!
May 4, 2026 7:41 AM UTC
Thank you! I saw the fix :)
