Imtiyaz_Ahmed
May 26, 2025
Figma Sites : Custom Domain Not Connecting
Hey Team,
I have been trying to link a sub-domain to my Figma Sites for a while and it’s not happening. I have a main domain ‘www.imtiyazahmed.com’ and I created a sub-domain from it : ‘kittu.imtiyazahmed.com’
I followed the proper procedure to add the DNS Records, name and values. I buy and maintain my domains in GoDaddy site. Once I added this sub-domain to Figma Site, it told me that it might take upto 24-48 hours for the changes to go live.
I waited for 48 hours, there was no update. Then I disconnected the domain, deleted the records and recreated the subdomain and DNS Records. I added it to Figma site again and waited for 48 hours and yet there was no update. It kept showing me that ‘it will take more time’
Kindly help me out. I have attached the images for your reference. Both of figma sites and godaddy dns record screen shots.
GoDaddy DNS Record :
Figma Sites :
Tom Reem
Tom ReemSolution
Hey everyone — good news!
Figma Sites now supports apex domains and custom subdomains, giving you more flexibility when personalizing your URL. Thanks so much for your patience and feedback along the way. ✅
You can find all the details and setup resources in this announcement: New feature: Apex domains and custom subdomains in Figma Sites.
Alexandra Ionesi
Hi! I have the same problem. Did you find a solution for this?
Imtiyaz_Ahmed
May 26, 2025
Not yet. I was hoping to find a solution through this article. If this persists, I was planning to Mail figma officially because this breaks the whole point of having and using figma sites.
One alternate way I am currently solving this is by using “Domain forwarding”. Temporary solution to make sure a sub-domain is being used but is not useful in many cases
Alexandra Ionesi
Thank you for the reply. I’m planning to mail figma too. I’ll let you know if something changes
Imtiyaz_Ahmed
May 27, 2025
Hey,
Hope you are doing good. So the issue has been resolved.
I wrote an email to Figma yesterday in detail and they help me figure out the problem. In my case the issue was that I was not adding all DNS records in GoDaddy.
Figma Sites specifies that two records need to exist - ‘cname’ and  ‘txt’
I was created DNS record for only cname, cause I thought only one of them was needed. Once I made sure both DNS records got added in GoDaddy, the subdomain was connected successfully.
Alexandra Ionesi
Hey,
Thanks to ChatGPT I found the solution to my problem and what worked for me was switching from the apex domain to the subdomain. Figma doesn’t support apex domains like mysite.com, so I connected www.mysite.com instead.
I set the TXT and CNAME records with those Figma provided then I set up a redirect from mysite.com to www.mysite.com through my domain registrar. That way, everything points to the version Figma actually supports — and it works now.
Imtiyaz_Ahmed
May 27, 2025
Hey,
Hey,
Glad things worked out for you. Yayayya let’s go
Zhalgas_Kassymkulov
Yes, exactly the same problem.. It was frustrating making all those redirects. Why wouldn’t Figma support apex domains? We’re all used to them, no one types in www anymore, and setting up those redirects was hell.
Tom Reem
Hey everyone, thanks for sharing your experiences with this! I wanted to check in and confirm that support for apex domains is on our radar and will be available soon. ⏳
We’ll share any updates as they roll out, and you can also keep an eye on this Help Center article for the latest: Does Figma support apex domains?
Really appreciate your patience as we continue improving Figma Sites based on your feedback. 🙏🏻
Tom Reem
Tom ReemSolution
David_Claytor
Working through this I had the exact same issue. It was not apparent to me that these records need to be added on the main domain. My host, Dreamhost, allows subdomain DNS editing but their formatting for TXT records is different than what Figma requires so these had to go on the apex domain’s DNS settings. It could be a little more explicit on where to add these records.
