Anirudh KS
Nov 10, 2025 7:35 AM UTC
Figma sites - alignment/ layout broken after publishing
I have designed a website using Figma sites. The alignment is perfect in the preview mode. However the published site looks distorted. Common problems like center aligned objects moving to the left (I saw other users mention the same concern)
Kindly help me fix this at the earliest.
Nov 24, 2025 3:49 PM UTC
Hey Anirudth, thanks for raising this! I see in the backend that you have already reached out to the support team, thanks for doing that!
I’m sharing here the guidance our team recommended, in case it helps you or anyone else who might run into the same behavior: based on how your layout is currently set up, what you’re seeing appears to be expected. The team suggests reviewing this article on building responsive designs with Auto Layout. When you resize the preview, you’ll notice it matches exactly what appears on the published page.
If this doesn’t resolve the issue, please continue the conversation directly in your support ticket. The team will be able to look into your case in more detail from there.
For others, feel free to share a report so our team can have a look at it here. Thank you!
