Vladimir Bulavko
Sep 1, 2026 3:16 PM UTC
Figma plugin is missing from ChatGPT/Codex plugin library
Problem:
  • Figma does not appear in the Plugin directory in ChatGPT web or the desktop app.
    The search returns no results.
  • The official Figma plugin page shows “Add plugin.” When I select it, I get this error: “We couldn't load this plugin right now. Please try again in a bit.”
  • The problem occurred on August 31 and September 1, 2026.
    Sep 1, 2026 8:15 PM UTC
    Hi ​@Vladimir Bulavko, thanks for flagging this!
    I understand how this must be slowing down your work. This seems specific to your ChatGPT/Codex setup rather than something broken on our side. The most common cause for Figma not appearing in the directory is plugin permissions at the ChatGPT workspace level. Third-party plugins are disabled by default in many Business and Enterprise workspaces, which both hides Figma from search and can make "Add plugin" fail with the exact error you're seeing. Two things to try:
    1. If you're on a Business or Enterprise ChatGPT workspace, ask your ChatGPT admin to confirm third-party plugins are allowed and that new tool additions are approved.
    2. In the meantime, you can skip the plugin and point Codex at the Figma MCP server directly.  The Codex and Figma setup guide covers this, along with a troubleshooting note on the admin settings above.
    Let us know how that goes, and we’ll continue to investigate this together.
    Vladimir Bulavko
    Sep 2, 2026 8:42 AM UTC
    Hi, thanks for your reply. I’m on personal ChatGPT Plus plan.
    The thing is that I do see Figma skills in Skills Directory, but no Figma plugin is returned when searching Plugins directory.
    I was able to install the Figma skills and triggered connection to my Figma account.
    Still odd why it’s not showing in Plugins.
    doripoison
    Oct 27, 2026 1:46 PM UTC
    Hello, have you resolved your issue? I'm having the exact same problem right now. I can't find Figma in the plugins; it just disappeared. I can't find any information about it… Could you help me figure this out? Thanks in advance.
    Vladimir Bulavko
    Oct 27, 2026 4:07 PM UTC
    Nope. my workaround was that I still could see Figma skills in the Skills section, so I installed all of them.
    I suppose the reason is that I’m on 13.7.8 Ventura with Intel chip, so they could silently stopped supporting the plugin for it.
    adamsmasher
    Oct 28, 2026 10:01 PM UTC
    Thanks for the additional details, ​@Vladimir Bulavko, and for flagging that you’re seeing this too, @doripoison.
    While the admin-level setting wouldn’t apply for you with ChatGPT plus, ​@Vladimir Bulavko, you may want to check this ​@doripoison, if you are on a Business or Enterprise ChatGPT workspace. Also, what version of Mac OS are you using? Is it also an Intel machine like Vladimir?
    Question for both of you: is Figma also missing when you search Plugins on the web while signed into the same personal account? In the meantime, I am checking with the team to confirm if there’s any restriction around OS version/Intel chips.
    Vladimir Bulavko
    Oct 29, 2026 10:56 AM UTC
    actually today the Figma plugin appeared both in web and desktop ChatGPT apps! Good job!
    Thank you.
