Booluigii
Sep 27, 2026 2:50 PM UTC
Figma Motion : Gif export problem
Hello Figma,
I use Figma Motion because it’s easy to make a basic motion without export many files.
For the context, i make a 20 seconds timer with animation at the beggining and the end of animation.
The start and end animations each last 1 second with 0.5 seconds of blank before or after.
But i have a mysterious problem, i would like export to GIF because it’s the only format who accept transparent background.
But when i export a 30 seconds motion in GIF ( 1080p / 30fps / x1 / Loop doesn’t matter ) , the GIF last 28 seconds.
And when i see the GIF, i see my timer of 20 seconds is 2 seconds shorter like it’s more speedy than the timeline show.
I test with MP4 ou WEBM, exports last well 30 seconds.
And the antoher GIFs i made with Figma Motion are shorter than MP4 or WEBM export. ( Timeline show 13 secondes, but the export takes 11 seconds. )
Can you fix this problem ? Thank you !
( If I could make a suggestion, it would be to be able to create a key image for text editing, because doing 13 layers to do 2 to 0 and 9 to 0 for the timer is a bit long to do. )
I wish you a good day and goodbye!
Jaycee Lewis
Sep 28, 2026 9:42 PM UTC
Hey hey ​@Booluigii 🤩 Thank you for both the feedback and for flagging your issue. Are you able to grab a not-zoomed-in screen recording or GIF of the expected playback and the export that is missing time, please? This will help me triage this effectively. Talk soon! — Jaycee
Booluigii
BooluigiiAuthor
Sep 29, 2026 5:15 PM UTC
Hi !
If you prefer, the final rendering has a x1.11 speed.
That’s what I wanted, but it’s just faster than expected.
For example : 30s in timeline have a 27s export and a 190s have a 171s export.
I think the 30 fps export are in fact a 27 fps. ( I calculate 30*1/27 to determine the speed ).
Jaycee Lewis
Sep 30, 2026 10:32 PM UTC
Hey ​@Booluigii 👋 Can you please submit a bug report through the Support Hub: Support Hub  >  Type “Report a bug” > Click Start a chat > select Enter and follow the prompts. In the form, include the URL of the file and grant "View" access with support-share@figma.com, this allows us to reproduce the issue and investigate. Adding example exports that have the discrepancy you describe will be helpful too. Thanks again — Jaycee
