bmpq1352
Oct 2, 2026 4:35 PM UTC
Figma Motion exporting problem when using a shaders
Hi
When im rendering an animation using shaders to MP4 and GIF formats, an error occurred in the rendering window: "Failed to render the shader effect for this frame, so the export was stopped."
Sometimes there is no error, but rendering is stuck at 10% and doesn't move at all.
Animation and shaders work fine in Figma.
File with this problem - [redacted by forum moderator to remove PII]
How can I fix this?
Thanks
Render settings - MP4, high quality, and 30 fps
Windows 10 (22H2), Figma version 126.9.11, Chrome 154
bmpq1352
bmpq1352Solution
Oct 3, 2026 12:26 AM UTC
I checked again and the problem persisted; then I went into the settings, found the "Prefer High Performance GPU" option, and enabled it—that helped solve the problem. 👍
Jaycee Lewis
Oct 2, 2026 9:43 PM UTC
Hey, ​@bmpq1352 👋 Thanks for reporting this. Are you still having the issue? I tried both export modes after animating a simple shape and shader (excuse my simple example lol).
Please submit a bug report through the Support Hub: Support Hub > Type “Report a bug” > Click Start a chat > select Enter and follow the prompts. In the form, include the URL of the file and grant "Can View" access with support-share@figma.com, this allows us to reproduce the issue and investigate. If you can record a quick gif or screen recording of the issue happening, that will be helpful too. Thank you! — Jaycee
bmpq1352
bmpq1352AuthorSolution
spark_d
Oct 18, 2026 10:36 AM UTC
what settings? on figma?
