Артём маликов
Sep 28, 2026 4:26 PM UTC
Figma MCP upload_assets returns HTTP 405
Hello Figma Support,
I’m working in ChatGPT with the officially connected Figma MCP plugin. I have edit access to the target file, and other canvas editing actions work, but image uploads fail.
On September 28, 2026 at 16:18 UTC, I requested a fresh submitUrl from upload_assets for file E1r9TavVGj7XrvGMaL6RAb. Following the tool’s preferred instructions, I sent a 706,594-byte PNG via POST as multipart/form-data, with the image in the file field.
The endpoint on mcp.figma.com returned HTTP/2 405 Not Allowed, with a 163-byte HTML response from openresty/1.27.1.1. There was no Allow header or request ID, and the image was not placed.
Could you investigate why the fresh upload URL rejects the request format specified by upload_assets?
Jaycee Lewis
Sep 28, 2026 6:33 PM UTC
Hi ​@Артём маликов 👋 Thank you very much for your detailed post.I have a few questions:
  • Could you share the upload_assets tool call and its complete response, especially the upload instructions? Seeing the HTTP request (method, URL path, Content-Type, and body format) and the response status, headers, and body is super helpful for troubleshooting. (Please redact the full submitUrl, including its query string, along with any credentials)
  • Was this in ChatGPT, the Codex app or CLI, or another client?
If you’re comfortable, here’s a quick test to see if we get success or another 4XX response:
Using the same session in Codex (if possible), request Codex to use fresh upload URL and send the same PNG as raw bytes:
curl -i --request POST \
--header 'Content-Type: image/png' \
--data-binary '@/path/to/image.png' \
'<fresh submitUrl from upload_assets>'
Make sure to replace both placeholders locally.
Talk soon! — Jaycee
Артём маликов
Oct 2, 2026 8:47 AM UTC
Hi Jaycee,
I ran the test in the ChatGPT web interface with the officially connected Figma MCP plugin, not in the Codex app or CLI. The connected account is artmalikoff@gmail.com. I can edit the target file: I successfully created a square in the same frame after the upload test.
Here is the upload_assets call:
"fileKey": "E1r9TavVGj7XrvGMaL6RAb",
"currentPageId": "264:16525",
"count": 1,
"nodeIds": ["444:5193"],
"scaleMode": "FIT"
Here is its complete text response, with only the full submitUrl redacted:
"uploads": [
"submitUrl": "[REDACTED: FULL URL INCLUDING QUERY STRING]",
"targetNodeId": "444:5193"
"instructions": "Upload each asset by POSTing to the submitUrl. You can POST the upload URLs in parallel. You can use either format:\n1. multipart/form-data with a 'file' field (PREFERRED — the filename from the upload is used as the layer name in Figma)\n2. Raw bytes with the correct Content-Type header (e.g. image/png, image/jpeg)\n\nSupported types: image/png, image/jpeg, image/gif, image/webp, image/svg+xml. SVGs (image/svg+xml) are imported as editable vector node trees; nodeId, nodeIds, and scaleMode do not apply to them. Each URL is single-use and expires after 10 minutes. The response from each POST will contain the imageHash and placement details."
I sent HIBERG_HDQ11-10_B_prepared.png (706,594 bytes) to the fresh URL as requested:
POST /mcp/upload/[REDACTED ID]/submit?[REDACTED QUERY] HTTP/2
Host: mcp.figma.com
[raw PNG bytes; not multipart/form-data]
The equivalent curl invocation used --request POST, --header 'Content-Type: image/png', and --data-binary @...png. The upload response at 2026-10-02 08:32:35 UTC was:
HTTP/2 405
server: openresty/1.27.1.1
date: Fri, 02 Oct 2026 08:32:35 GMT
content-type: text/html
content-length: 163
Complete response body:
<html>
<head><title>405 Not Allowed</title></head>
<body>
<center><h1>405 Not Allowed</h1></center>
<hr><center>openresty/1.27.1.1</center>
</body>
</html>
No Allow header or request ID was returned. The PNG was not placed. I removed the empty temporary target layer afterward; the existing image in the frame remains intact.
Ira999
Oct 15, 2026 6:01 AM UTC
Hi everyone! I’m experiencing the same issue. Has a solution or workaround been found yet?
adamsmasher
Oct 15, 2026 10:28 PM UTC
Hi, ​@Ira999. Thanks for your reply - it’s unfortunate you ran into this issue, too.
Could you try again and let me know the following information?
  • The exact time the failed attempt occurred
  • The timezone for that timestamp
  • Any error message shown in ChatGPT for that specific attempt
  • A link to the Figma file you were trying to add the image to, shared with support-share@figma.com with view access (this won’t affect your billing).
I’ll share that with our engineering team to review with the current report. Thanks!
Elene Chekurishvili
Oct 20, 2026 10:43 AM UTC
I’m experiencing this too through the Figma connector in ChatGPT. Today, authentication and file reads worked, but image uploads returned HTTP 405 using the documented POST method, with both multipart and raw JPEG uploads. The files were valid JPEGs under 150 KB.
Reconnecting and reopening hasn’t helped. Connection issues have been interrupting my design workflow almost daily, and this upload failure is currently blocking image placement. Is there a confirmed workaround or an update on the investigation?
