Joe_Flag
Jul 8, 2025 3:41 PM UTC
Figma MCP does not pick up Code Connect snippets using Cursor
Hello!!
I have code connect snippets set up within my Figma system and I am attempting to use Cursor to get the code from Figma. When I try to do this, I am receiving this response, stating no Code Connect files exist.
Below is a screen shot of my frame and connected snippets. Did anyone else encounter this problem and have any solutions? This was working for the past two weeks so wondering what has changed with MCP or Cursor.
Lukas Heddendorp
Jul 16, 2025 9:26 AM UTC
I have the same problem.
Also code connect is set up in html mode
Jul 17, 2025 8:40 AM UTC
Hi ​@Joe_Flag ! Thanks for reaching out. I see you've already contacted our support team.
Just sharing here for visibility, at the moment, this command works only on instances, not on component variants. Apologies for any disruption this may be causing. The team is actively reviewing this and exploring possible solutions going forward.
Our technical quality team is also waiting for your response to continue investigating your case. When you have a moment, please check your support ticket.
For anyone else experiencing similar issues (​@Lukas Heddendorp), feel free to reach out to our support team so they can take a closer look into your case. Thank you!
