goutham123
May 3, 2026 2:32 AM UTC
Figma make unable to restore older version
Hello , I was using AI to work on a project. It worked fine until the AI credits got finished midway. When I resumed the next day I could see it has completely messed up the code and lost everything. I tried to restore to an older version and It still is not able to restore it.
this is the project I was working on
Tom Reem
May 3, 2026 12:03 PM UTC
Hi ​@goutham123, welcome to Figma Forum, and sorry to hear about the trouble with your Make file.
Let’s take a closer look together — here are a couple of things that would help me understand what happened:
  1. What are you seeing now? Can you describe what the code looks like after it broke — is it partially there, completely different, or blank?
  2. Version restore behavior: When you try to restore a previous version, what happens? Does it fail silently, show an error, or restore something that still doesn't look right? If you're seeing an error message, check whether it matches anything here: Troubleshoot in Figma Make → Error messages.
I've also opened a ticket on your behalf with our Technical Quality team so they can take a closer look. Your case number is: 1881905. To help them dig in, please:
  • Grant view access to support-share@figma.com on the affected file.
  • Share a screen recording showing the issue in action (if possible).
Check your inbox for an email from me with next steps on sharing the file securely. 🙏🏻
goutham123
May 3, 2026 1:48 PM UTC
Hello Tom,
I have shared the view access to the project . It is shared between two accounts my starter account and my education account which i created later.
 Version 7 of the project worked fine , but while working on version 8 the credits ran out  and had to wait till evening. I tried to get it fixed but to no avail. Please can you restore the older versions or fix the ability to switch to older versions, it would be very helpful.
goutham123
May 5, 2026 8:14 AM UTC
please close this issue. I managed to use the figma make AI to restore the older files using a older backup. Learnt my lesson , will not trust figma to safely keep my backup
Tom Reem
May 5, 2026 1:58 PM UTC
Hi ​@goutham123, glad you were able to find a way forward, and thanks for following up.
I hear you on the backup concerns — your experience is noted and I've shared it with the team. Feedback like this helps us improve.
If anything else comes up, don't hesitate to reach out. 🙏🏻
goutham123
May 5, 2026 8:55 PM UTC
thanks , I actually enabled github integration now . I should I have done it before . Thanks for looking into this anyway
