ParasMDesigns
Nov 15, 2025 10:00 AM UTC
Figma make to figma design copy not working properly
I’m experiencing a persistent copy–paste issue in Figma.
Whenever I copy frames or components from Figma Make to a Figma Design project, the layout gets distorted — spacing changes, auto-layout breaks, and typography styles don’t map correctly.
If anyone has faced this and found a reliable solution, please share. This is slowing down my workflow, especially when combining Make explorations with production-ready design files.
Deok Filho
Jan 29, 2026 10:00 PM UTC
I’m having a similar issue.
When I paste into Figma Design, I only get a portion of the design (menu options, which are part of my design). But I don’t get any of the other content (the most important part) i.e. form components, buttons, fields, headers, etc. This happens from wherever page I happen to copy from.
Celyn_L
Feb 3, 2026 8:08 AM UTC
Hi ​@ParasMDesigns — Celyn from Figma Community Support here. Noticed your post was from a while back, sorry for the delayed response 🙏
Please let us know if you’re still experiencing issues!
Celyn_L
Feb 3, 2026 8:19 AM UTC
Hi ​@Deok Filho — Celyn from Figma Community Support here.
Thanks for flagging this and for sharing the context. I’m sorry you’re running into issues with copy-pasting into Figma Design.
Could you please review the steps below to confirm everything is set up correctly?
  • Make sure you’re viewing the preview of your Figma Make file. As a quick check, you can also try refreshing the preview or the page.
  • Navigate to the specific state you want to copy (a page, screen, or interface view).
  • Click the “Copy design” icon at the top of Figma Make.
Here’s the guide for reference: Copy a Figma Make preview as design layers​​​​​​
If the issue persists, it would be really helpful if you could share a screenshot or screen recording showing the steps you take (with the full Figma window visible)
Please also share your impacted file with support-share@figma.com and grant “Can View” access — This will not impact your billing and will allow us to reproduce the issue and investigate with Engineering.
Thanks!
abestman nse
Mar 4, 2026 4:39 PM UTC
I’m unable to copy design from Figma make.
The copy design button is greyed out.
Celyn_L
Mar 13, 2026 9:50 AM UTC
Hi ​@abestman nse — I’m sorry to hear that you’re unable to copy your design from Make and that the button is greyed out. Are you still experiencing this issue?
If so, could you please submit a bug report through the Support Hub so the team can take a closer look?
To do this:
  • Go to the Support Hub
  • Click Start a chat
  • Type “Report a bug” and follow the prompts
Thanks!
abestman nse
Mar 13, 2026 12:03 PM UTC
Hi Celyn
thanks for reaching out
nope the issue has been resolved
cheers
Sarika Arora
Apr 19, 2026 5:47 PM UTC
Hi Celyn,
It looks like copying and pasting from Figma Make is inconsistent. Sometimes it copies the entire page, and other times it only copies part of it. Do you know how to fix this?
Sarika
Celyn_L
Apr 20, 2026 5:36 AM UTC
Hi ​@Sarika Arora, thanks for flagging this.
That does sound inconsistent, and I’d like to help narrow down what’s happening. Could you share a bit more detail on your setup?
  • When only part of the content gets copied, is it consistently missing certain elements, or does it vary each time?
  • Does this happen every time you copy, or only with specific Make outputs/pages?
  • Where are you pasting the content (same file, new Figma file, or external tool)?
As a quick check in the meantime, a couple of things that might help:
  • Try selecting everything using Cmd/Ctrl + A before copying, instead of drag-selecting
  • Try copying from a fresh Make file to see if the behavior is the same
  • Switch between Desktop and browser to see if there’s any difference
This guide might also be helpful, as it covers copying content from Figma Make previews into design layers:
If you’ve tried these and the issue is still happening, the best next step would be to submit a bug report so the team can take a closer look at what’s happening in your specific setup.
You can do that by:
  • Going to the Support Hub - Clicking Start a chat -Typing “Report a bug”
When submitting, it would be really helpful to include:
  • A direct link to the affected file
  • Invite support-share@figma.com with “Can View” access (Note that this will not impact your billing and allows us to reproduce and investigate the issue with Engineering)
  • Any screenshots or screen recordings showing the issue
Let me know how it goes!
