Gart
Feb 25, 2026 3:35 PM UTC
Figma Make started not rendering a third party library component a month ago. Any idea?
At the beginning of the year I started experimenting with Figma Make using our React component library along with “Syncfusion”, a third party component library we use.  A new release of Figma Make around the end of January saw “tabs component” of this thrid party library unable to render in Make.  It will show up on page load then disappear once does “Refreshing”.  I know what your thinking “It is the third party library”.  I assure you I have tested this component with the exact same code in every other environment and it works.  I even isolated the tab code in Figma Make and it still doesn’t render.
My real question is, did anything change in the way Figma Make renders the React chunks?  It is showing up with content and then ripping it away when loading chunks from React components.
Gart
GartSolution
Feb 27, 2026 3:06 PM UTC
This issue was resolved in the recent release.  Thanks.
Gart
GartAuthorSolution
Feb 27, 2026 8:51 PM UTC
Glad to hear this, ​@Gart!
Thanks for letting us know. If you run into any further issues, please do keep us in the loop.
