Tiago Antonio
Sep 17, 2025 8:02 PM UTC
Figma Make shows "Try again with fewer inputs" in any prompt
I've seen here on the forum that many people are having the same problem. I've tried duplicating the file, and this message still appears, even with short prompts. Does anyone have a solution?
Sep 18, 2025 5:35 AM UTC
Hi ​@Tiago Antonio ,
I understand you're encountering the “Try again with fewer inputs” error in Figma Make, even after duplicating the file and using shorter prompts.
This error typically occurs when the system is overloaded—either due to a large selection or a prompt that’s too complex to process. Since you've already tried duplicating the file, here are a few more steps you can try (if you haven’t already):
  • Try using the Point and Edit tool to prompt and edit more targeted sections of your design.
  • Reduce the amount of content in your prompt or break it into smaller steps.
While we’ve seen a few similar reports, I haven’t been able to confirm a widespread issue at the moment. In most cases, the root cause seems to vary by file, so investigating each case individually is necessary.
If the issue still persists, we recommend submitting a support request so our team can investigate further:  Submit a request
Please include the following in your submission:
  • A full-window screenshot or screen recording showing the issue.
  • Invite support-share@figma.com to the affected file with “can edit” permissions and add it to your team (don’t worry, this won’t count toward billing).
  • Reproducing the issue, then export and share the console log: Export console logs and share the
We really appreciate your help in getting to the bottom of this!
