samschwa
Oct 31, 2025 7:28 PM UTC
Figma Make "Select a Design Library" button is broken.
I’ve been iterating on a design in the Figma Make tool, and I’m using a design library, which I imported using the “Select a Design Library” button at the bottom of the prompt window.
However, I recently tried to get the AI to use an element in that library, and the design broke. Since then, the button has been empty, and the AI seems to think I don’t have any library selected. I can’t click anything to re-add the library, or to reset the button. I’ve had a coworker look at the design, and it’s also broken for them as well.
I can provide further info/console logs if it’s useful.
ksn
Nov 14, 2025 11:01 PM UTC
Hey ​@samschwa - thank you for reporting. I do think it would be super helpful to provide that info and get someone on our support/engineering team to take a look, since it seems to involve an issue with Figma Make specifically.
Could you please fill out this form and let me know when you’ve done so? I’ll make sure it gets routed to the right place. Thank you!
