Brie Greenawalt
Aug 31, 2026 4:04 PM UTC
Figma Make not updating published version
I just made a research website through Figma Make. Overall I’m happy with it but I am experiencing an issue with one of the right side panels where the panel is behind the navigation and I cannot close the panel.
No big deal so I went in to edit the padding as a quick fix because I ran out of credits and just need it to work.I figured it out and it works in the Figma Make perfectly.
However I then go to publish this change, it loads, says its complete but the change is not reflected on the actual site. I’ve tried clicking apply in the left chat area after making a change which just makes it sparkle? I’ve changed browsers, I’ve disconnected my VPN, I’ve tried multiple other changes to achieve the same end result. Nothing is working. No changes are being published. Am I missing something?
Jaycee Lewis
Aug 31, 2026 9:16 PM UTC
Hi, ​@Brie Greenawalt 👋 I’m sorry to hear about this. Happy to help.
Two things to check:
  • Click the version number at the top of this Make file. Did a new version get created after you made the padding change?
  • How did you make the padding change? Using the Edit tool and properties, or directly in the code tab?
One thing to be aware of: “Note: The changes you make aren't committed until you click Apply. Changes made with the properties panel use AI credits” — link
Talk soon! — Jaycee
