Sebastiaan_bestbonobos
Jun 23, 2026 2:27 PM UTC
Figma make keeps showing same error, even after restoring older version.
Figma make keeps showing same error, even after restoring older version. Not sure what goes wrong, refresh doesnt work, shorter or simpeler prompt doesnt solve this either.
Error code 2nd time: 7f825515-eab9-4fe7-8f7a-499a2fe13f07
A short view of an API error for half a second appears
even after duplicating the file and trying to make a small textual change in the copy i receive an error.
Jun 23, 2026 3:28 PM UTC
Hi ​@Sebastiaan_bestbonobos , thanks so much for all the detail you shared! The steps you tried and especially those error IDs are helpful.
I've created a support ticket on your behalf and I'm passing this on to our Technical Quality team, who are better placed to investigate what's happening on the backend. They'll be in touch to follow up. For reference your case number is 1977559, sent to your email address: sexxan@bexxos.xxm.
In the meantime, two more things worth trying if you haven't yet:
  • As a first step, try switching the AI model you're using. We've seen this resolve the "something went wrong" error for other users in similar situations.
  • Open a brand new Figma Make file (not a duplicate of the affected one) and test a very simple prompt from scratch. This can help clarify whether the issue is tied to the original file's history or something broader. Feel free to explain the steps you have already done directly in your support case. Thanks for your patience, we're on it!
    Update: The support agent has replied to you with some next steps, please check your inbox when you can, thank you!
