Dec 8, 2025 9:00 AM UTC
Figma make just deleted 90% of my project - 2 weeks of work gone, cannot be reverted
Hi,
I need urgent assistance. I created a full interactive dashboard prototype in Figma Make, then added a homepage and login structure. When I tried to edit a single section on the homepage using Point to edit, the platform deleted the entire project except for the edited div.
My website, dashboard, and two weeks of work are completely gone.
I cannot revert the changes because the entire file structure and codebase were deleted — there is nothing to restore on my end.
I urgently need to know if you have any versioning or backup system that can recover the project immediately. I was scheduled to present this to investors today, and this loss is critical.
I contacted support three days ago but still haven't received a response.
Support ticket: 1629841
Please escalate this and help me retrieve the project as soon as possible.
Thank you.
Celine_Solution
Dec 8, 2025 9:45 AM UTC
Hey ​@K8e , thanks for reaching out to the Figma Forum, and sorry to hear about what happened with your Figma Make prototype.
I checked on my side, and I was able to see your ticket in the backend. I’ve escalated internally and added a note to your ticket so our team is aware of your follow-up. They’ll review your case as soon as possible.
In the meantime, there is one thing you can try while waiting for the support team’s investigation. Figma Make automatically creates version checkpoints throughout your AI chat, so you may be able to revert your project to a state before the unwanted changes occurred.
Here’s how you can restore a previous version:
- In the AI chat, look for the ‘Restore this version’ button next to earlier versions
- Select the version you want to return to
- Click Restore this version
For more details, you can check our guide here.
A few important notes:
  • Restoring a version doesn’t delete later versions or steps of your conversation. You can switch back to them anytime.
  • Version history is the best immediate way to recover earlier working states while the support team investigates.
I know this situation is critical, and I’m really sorry for the disruption. Thank you for your patience while the team looks into your case, they’ll follow up with you directly through your support ticket.
Celine_Solution
K8eAuthor
Dec 8, 2025 10:59 AM UTC
Thanks, Celine.
I’ve now managed to revert to an earlier version of the project.
However, when I tried to do this on Friday, it did not work. I kept getting a message along the lines of: “Cannot revert, the files are missing. There’s nothing to do here.”
I’m still very concerned about what caused this issue and how I can avoid it in the future. At this point, the system feels unreliable for production work, and I need to understand whether this was a bug, an edge case, or expected behaviour.
Could you please explain what happened and what steps I should take to prevent this from occurring again?
Dec 8, 2025 1:39 PM UTC
Thanks for the update, I’m really glad to hear you were able to restore an earlier version!
Regarding the “Cannot revert, the files are missing” message you saw on Friday, it’s not possible to determine the exact cause from the Forum alone. This will need a closer investigation by our support and engineering teams, as it involves file-specific details.
I can see that your support ticket is still open, and it has already been escalated to our Technical Quality team. They’re currently waiting for your response, so when you have a moment, please reply directly in your ticket. They’re the best equipped to review what happened on the backend and confirm whether this was a bug, an edge case, or expected behavior.
Thank you again for your patience while they continue the investigation with you. Since you were able to restore your file, I’ve gone ahead and marked this thread as solved here.
APRO
Apr 30, 2026 7:04 PM UTC
The revert bottom is not working at all. This is carzy. how Ai can suddently delete all the files. And revert bottom is not working at all
adamsmasher
Apr 30, 2026 8:49 PM UTC
Hi ​@APRO. Sorry to hear that you’re having issues reverting your Make file - it sounds pretty frustrating.
I found a ticket you submitted regarding this and let our support team know that you posted here; you should hear back soon from our team. Thank you for your patience!
In the meantime, let’s see if we can figure out what might be happening. When you click the Version dropdown in Figma Make, do you see a list of previous versions? The Restore this version option is disabled for the current app version, but it should be available on previous versions (see my screenshots below).
Restore option disabled because this is the current version.
Restore option available on a previous version.
Do you see something different from this? If you do, I recommend replying to your ticket and explaining what you see so our support team has the most up-to-date information.
Tsele
May 19, 2026 12:22 PM UTC
Hi, I’m having a similar issue with one of my Figma Make prototypes. When I try and restore any previous version (using the Version history dropdown, as shown in the message above), Make says it can’t fetch it. We’ve also tried prompting Make to undo changes and revert to an earlier version with no success. There is no preview and it appears as though all / key files have been deleted somehow.
Jaycee Lewis
May 20, 2026 11:15 PM UTC
Hey, ​@Tsele 👋 Thanks for flagging this. I opened a support ticket for this case (ID 1910894) I see you responded and shared a .mov file. Thank you very much.
We’ll keep the communications there, but if you need help with anything else, please don’t hesitate to reach out. — Jaycee
