PearlZHU
Nov 18, 2026 3:43 AM UTC
Figma Make failing across all files — "Live preview failed" + makeproxy-m blocked
Hi Figma team,
I'd really appreciate some help troubleshooting Figma Make. It's currently completely unusable across all files, not limited to a single document.
Errors I'm seeing:
  • "Something went wrong. Try again." — srid_97NXFWV65TSXN49H4Q2QJ8E8Q
  • "Live preview failed" — srrid_ZS0PFQ4QSYMQPKSMMFN5KA6SZ
Environment:
  • Network: Home Wi-Fi (also tested on mobile hotspot — same result)
  • Browsers: Multiple browsers, including incognito mode with extensions disabled and cache cleared
  • Affected scope: Both new blank drafts and existing files — all fail
Network check:
In "Check network settings", most services show Available, but:
  • Figma Make - makeproxy-m → Blocked​ (*.makeproxy-m.figma.site)
Steps already tried:
  • Changed DNS to 1.1.1.1 and flushed DNS cache
  • Cleared browser site data and cache
  • Tested in incognito mode with all extensions off
  • Restarted router
  • Switched to mobile hotspot
  • Logged out and back in
  • Tested in fresh draft files
None of these resolved the issue.
Since the failure happens consistently across browsers, networks, and files, I've run out of things to try on my side. Could you please take a look at what's actually going on here?
I'm happy to share file links, screenshots, or any logs you need — just let me know what would help.
Thank you!
Pearl
Celyn_L
Celyn_LSolution
Nov 18, 2026 5:24 AM UTC
Hi ​@PearlZHU, Celyn from the Figma Community Support team here.
Thanks for sharing such a detailed report and outlining everything you’ve already tried. I’m sorry Figma Make is still failing across all your files.
The blocked *.makeproxy-m.figma.site domain could be contributing to the live preview failures. Please check whether any firewall, VPN, or security software on your device is blocking access to it. Since you’ve already tested both home Wi-Fi and a mobile hotspot, checking any restrictions on the device itself would be a useful next step.
If your device is managed by your organization, please ask your IT team to ensure this domain, along with the other domains listed in our network settings guide, is allowlisted in your firewall and security tools.
I’ve also created a support ticket so our team can investigate further. Your ticket number is #2268852. Please reply directly to your ticket with any findings from these checks.
Thanks for your patience, we’ll continue helping you through the ticket!
Celyn_L
Celyn_LSolution
PearlZHU
PearlZHUAuthor
Nov 20, 2026 1:58 PM UTC
Hi Celyn / Figma Support team,
Following up on ticket #2268852. I've completed the device-level checks you suggested and want to share an important update:
The issue reproduces identically on a completely different computer and a different network.
Summary of what I've now ruled out:
  • Two different computers (same error, same srid/srrid IDs)
  • Multiple networks: home Wi-Fi, mobile hotspot, and a separate network on the second machine
  • Multiple browsers, including incognito with all extensions disabled
  • Windows Defender firewall temporarily disabled, third-party security software paused
  • DNS set to 1.1.1.1, cache flushed, router restarted
  • New blank draft files and existing files — all fail
Check network settings consistently reports Figma Make - makeproxy-m → Blocked​ (*.makeproxy-m.figma.site) on both machines.
Error IDs for reference:
  • srid_97NXFWV65TSXN49H4Q2QJ8E8Q
  • srrid_ZS0PFQ4QSYMQPKSMMFN5KA6SZ
Since the failure is identical across two independent devices and networks, I don't believe this is something I can resolve locally anymore. Could your team please look into this from the backend — specifically:
  • Whether my account's AI/Make access is correctly provisioned and active
  • Why makeproxy-m.figma.site is being reported as blocked from two different environments
Happy to grant support-share@figma.com view access to an affected file, share screen recordings, or run any diagnostic you need. Just let me know.
Pearl
Jaycee Lewis
Nov 20, 2026 11:36 PM UTC
Hey, ​@PearlZHU 👋 Thanks for following up. Please reply directly to your support ticket (226885) as this keeps things organized and makes sure our technical team doesn’t miss any important updates from you to them or from them to you. – Jaycee
