ugursahin
Jan 2, 2026 9:20 PM UTC
Figma Make Cant Upload My Own Asset To Website I Created From Make
I create a portfolio website for myself on Figma Make just with prompts not from a design file. I want to upload my own images manualy (preferably just to drag) to my website and simply it cant make it done. Is there anyone having the same problem and there is a simply answer for this problem? It show me some solutions and they are not working.(etc. using unsplash or other sites or it create an image folder in code and i cant put my images to it, i get file not suppoted error every time.)
ksn
Jan 2, 2026 10:00 PM UTC
Hey ​@ugursahin - apologies if I misunderstood what you are trying to do, but I think what you’ll want to do is copy your make output and paste it into a design file to be able to edit? It won’t ‘sync’ the data between the design and make file, but you can see and collaborate on the design. See here for more info.
If I misunderstood what you’re trying to solve, please do reply and let me know.
ugursahin
ugursahinAuthor
Jan 3, 2026 10:39 AM UTC
Hello ​@ksn thanks for your reply, unfortunetly thats not the problem i want to solve. My problem is, i am trying to change my images in website i created, i add image below to describe my problem better. I just want to change this image with my own and it just cant be done. Figma Make offer me some solutions with uploading from link(not my first choice, as i say i want to change it manually.) and uploading from link even cant work. Should i try to make my design from all over or there is any solution for this problem?
Jan 5, 2026 3:42 AM UTC
Thanks for the following up ​@ugursahin, I’m working closely with ​@ksn.
I understand that you’re trying to replace an image in the preview of your Figma Make file with your own image.
If you already have the image saved locally and would like to manually replace the image shown in the preview, you can try using the Point and edit tool, which lets you directly select and update elements in the preview.
You can learn more about this here: Point and edit tool
If that doesn’t work, you can also try providing the image directly in the AI chat and asking Figma Make to update the image for you.
You can find more details in the “Use images to create with Figma Make” section of this guide: Explore Figma Make
