Claudia Bogliacino
Sep 21, 2026 9:03 PM UTC
FIGMA MAKE BUG REPORT, VISTA PREVIA EN BLANCO
En la app de escritorio, la vista previa en vivo de un archivo de Figma Make no renderiza: el panel central queda vacío con el mensaje "Sigue dando indicaciones para empezar a crear", aunque el archivo sí tiene contenido (Make reporta "Ha editado 4 archivos": src/App.tsx, src/index.css, etc.). El resultado solo es visible después de pulsar Publicar. Esto impide iterar con feedback visual. Ocurre de forma consistente desde hace más de un mes.
    Celine_Solution
    Sep 22, 2026 1:06 PM UTC
    Hey Claudia, thank you for flagging this! I will continue in English as I don’t speak Spanish, hope it’s fine!
    I can see on our end that a support agent has already replied to your case and is waiting for your response to proceed with the next steps. Please continue the conversation directly through your support case
    I’m also sharing the suggested troubleshooting steps here in case they’re helpful to other users experiencing the same issue. Since the code generates successfully but the preview returns an M8 error, the issue appears to occur while loading the preview rather than during code generation.
    Please try the following:
    1. Click Refresh preview at the top of the preview panel.
    2. Reload the Figma Make file.
    3. Temporarily disable any VPN, proxy, firewall, or browser extensions that could interfere with the connection.
    4. Try another supported browser, or switch between the browser and Figma desktop app.
    5. Duplicate the Make file and test the preview in the new copy.
    If you’re using a managed network, ask your IT team to confirm that the required Figma domains are allowed. Additional guidance is available in Troubleshoot in Figma Make.
    If these steps don’t resolve the issue, please reply directly to your existing support case so our support team can continue investigating with you. (The support agent is waiting for your reply, thank you!)
    Celine_Solution
    Claudia Bogliacino
    Sep 22, 2026 2:35 PM UTC
    1. Actualizar la vista previa se realizó en varias oportunidades
    2. 2. Recargar el archivo también, incluso se probó desde el navegador, considerando que podría ser de un tema de la app de escritorio.
    3. Se desactivó la VPN temporalmente y el problema persiste
    4. Duplique el archivo Make y el resultado es el mismo.
    5. No hablé con el equipo IT para saber si los dominios de Figma están permitidos. Ya que hace un tiempo funcionaba sin inconvenientes, pero como siempre están haciendo actualizaciones. Posiblemente haya algo. Voy a sugerir revisen los dominios.
    Claudia Bogliacino
    Sep 22, 2026 4:07 PM UTC
    Thanks for letting me know and for trying these steps! I’ve also shared to the internal team who follows up your support case. Please continue directly via your support case as our support team will best equipped to advise you for the next steps, thank you!
