Figma just stoped working. Is it me or someone else is facing the same issue?
i can not do anything except loading the file and doing a preview.
[Post title updated by a moderator on 20-Oct-2025: “Figma Loading Issues — October 20, 2025.”]
I thought it was just the libraries not loading for the file I was working on, but no, seems that Figma is not working for me at all either.
Files finally loading in for me, but I seem to not be able to work within my own files!?
yes
SAME! Not loading at all, and I’m not allowed to copy/paste in my file 😓
Same problem here. After I installed the last update everything has gone dark
Figma presumably relies on AWS, and they are having a major outage in one of their regions at the moment. They’ve issued a fix, but it’s being rolled out to all of their customers, which takes time.
I’m also seeing issues, specifically that the middle center UI (where you create new elements) is now missing - but everything else is largely working (although the account / home page isn’t loading).
It’s annoying and highlights why a fully offline version would be really good - but also not Figma’s fault (other than using AWS 😅)
Hey everyone — really sorry for the disruption today and appreciate you all flagging what you’re seeing.
Our engineering team is aware of these reports and actively investigating the cause. We’ll keep this thread updated as soon as there’s more information to share. In the meantime, you can check status.figma.com for real-time updates.
Thanks again for your patience while we work to get things back to normal as quickly as possible.
I really need Figma to be back, I couldn’t preview anything and it just kept loading.
YESSSS also not working for me. Im a student and Canvas is also down today. As well as amazon, snapchat, life360 and so much more.
Me too. it’s not connected to the Figma server. It was only working on locally. And when I deleted and re-installed it, it was completely dis-connected to the server.
I have the same issue as you , I thought it was my own issue, but I tried clean my cookies or change the web browser , but still not working
hi guys i  also have this problem
Quick update for everyone — our engineering team has identified the issue causing degraded or unavailable Figma services. It’s related to failures with AWS and other dependencies.
Work is already underway to mitigate the impact and restore normal performance. We’ll continue to share updates here as progress is made, and you can also check status.figma.com for real-time information.
Thanks again for your patience while the team works to get everything back up and running smoothly.
Same - Melbourne Australia
after so many uninstall and changing the browser , i finally find out the problem from the figma itself ..
Alguma previsão de retorno?
Justo me toca entregar un proyecto el dia de hoy y no puedo entrar a mis archivos por lo mismo, que horror
Exatamente! Tenho o mesmo problema. Fico aliviado por não ser só eu.
My Figma totally stopped working as well. I am glad I found this thread!
Is it only a problem after the update? Or does it affect Figma regardless?
The issue still there 😅
Same - Italy.
Fix please!
Figma dont work!
Shame on you, Figma.
I am using the installed Windows version. The program starts and I can draw in it. I discovered the malfunction itself and the server connection only when I couldn't find the export button 😁
