The Wise Red Dragon
May 30, 2025 11:55 AM UTC
Figma ignoring underline style changes in hover
Okay, I’ve spent WEEKS problem shooting this with ChatGPT and today I finally found out what was wrong. It was a bug. Nothing I did wrong.
So, I wanted to create a link navigation where the hover effect was an underline for the link text. First surpirse was that I couldn’t just do that inside my initial “Navigation button” component, because Figma overhauls text styles to be consistent within a component’s variants. Okay, easy workaround: create a Label component with an instance without underline and one with and use those inside the final button component using the underlined variant only in the “Hover” variant. I learned that interactions should only be done in the main component, not in the “Label” component. Okay, seemed to be working on the test layer, but moving it to the actual design page broke the interaction and nothing happened. Cue weeks of troubleshooting, creating and re-creating components, testing with background colour changes to see if at least the button hover instance works and the problem is between the Label component and the Button component.
Eventually I find out that sometimes Figma just “is blinded” if an underline is the only style change that occurs and therefore doesn’t trigger it in the design. Just changing the text colour by one number or adding a bold or italic on top of the underline effect and voilá everything works perfectly.
I think I’m more upset at Chat GPT for not making me test this in the first place instead of making me completely recreate my components and designs multiple times, when this could’ve been tested really quick and easy.
Anyone else bumped into this particular bug??
Jun 5, 2025 5:55 AM UTC
Hi ​@The Wise Red Dragon,
If I understand correctly, you're trying to show an underlined variant nested within your "Navigation button" component when you hover over it, but you're not seeing any change. Is that right?
I'm not entirely sure how your components are set up, but I just tested this on my end, and the underlined link showed up as expected when I hovered.
I might be misunderstanding what you're seeing, so could you please share a video recording demonstrating the behavior? Please include your component setup and prototype settings in the recording as well.
This will help us understand exactly what you're seeing and how we can best assist you!
Naomi Karyamsetty
Oct 20, 2025 2:49 PM UTC
Hi,
I’m not sure of the original person’s problem, but I recently observed a similar bug. Here’s my situation:
If a component uses a text style, and the component’s instance’s text has been edited, the ‘While hovering’ animation doesn’t seem to work. Recording attached:
https://drive.google.com/file/d/1B5tznLWbTqMthynbJC4dYvumHZ4S0Aqd/view
Best, Naomi
KiboM
Apr 11, 2026 12:01 AM UTC
Hi,
Encountered the exact same problem as Naomi’s. Appreciate the clear demonstration.
Any fix thus far?
Thanks!
Naomi Karyamsetty
Apr 12, 2026 8:29 AM UTC
Hello! I’m not sure there’s an official fix yet. I’ve just been detaching the text style. (Not practical for large projects.)
Naomi
