Figma: if/else navigation bug
  • September 3, 2024
  • 7 replies
  • 72 views
rwb_marns
I am trying to create an if/else navigation based on login state. Upon executing the feature, I noticed that the bug happened 4 times. See attached video
After clicking the refresh button, and continue the prototyping, it will work. However, in your next attempt in other component/element, it will happen again.
letscreate
  • September 3, 2024
Hey i have noticed this Problem with another user today…
above link is about similar issue that you are facing…
Lets wait for the admin response
alok.asthana
It’s not similar, as in my case I have multiple overlays mapped to different instances,
but in-order to open the right one it i have to reload the prototype, it starts repeating the previously opened overlay
  • September 3, 2024
Hey @rwb_marns , thanks for flagging this. As you received the notification ‘Figma ran into a problem’. As a first troubleshooting, can you please try clearing your cache in your browser and desktop app, and try accessing Figma again?
You can clear the desktop app cache on a Mac in the Help menu under Troubleshooting. If you’d prefer to manually clear your cache you can:
  1. Quit the Figma desktop app
  2. Open Terminal.app and enter the following command: rm -rf "$HOME/Library/Application Support/Figma"
  3. Try opening the desktop app again
You can clear the desktop app cache on Windows under the toggle-arrow at the right of the top toolbar under Help > Troubleshooting. If you’d prefer to manually clear your cache you can:
  1. Close the Figma desktop app
  2. Open the Start menu, and paste in this, followed by enter: %APPDATA%\Figma
  3. In the window that opens, delete the Desktop and DesktopProfile folders if they exist
  4. Launch the desktop app again
If this doesn’t help, please reach out directly to the support team so they can take a look at your issue by filling this form: here
Please use your Figma account email and share your console log (you can follow the steps in this article here) so they can take a closer look.
For others (@letscreate @alok.asthana ), please also try to clear out the cache to see if that helps. If not, I’d also recommend you to reach out directly to the support team here for further investigation.
(If your issue happens in a specific file, please also share to the support team (in the form) a link to the file, and add support-share@figma.com as an Editor and a quick screenshot/ video recording, so they can take a closer look. Thank you!)
rwb_marns
  • September 3, 2024
Hi @Celine_Figma,
Upon reporting the issue, there’s a field there that is required which is to ask the working file in which I cannot disclose since it is from the company I’m working on.
Can you help us to raise this concern to the support team?
rwb_marns
  • September 3, 2024
By the way, I am using Figma from Web.
  • September 3, 2024
Hey @rwb_marns , sure, I’ve filled out a support ticket on your behalf, the ticket number is 1111416 for your reference. You should have received my message via email (I sent to this address mail: mxxxxxxn.cxxxa@rxxxxxxr.com). The support team will reply you soon. Thanks for your patience in the meantime!
rwb_marns
  • September 4, 2024
Thank you @Celine_Figma!
