Mona Aymn
Apr 13, 2025 11:56 AM UTC
Figma exports only 1 item then needs to reload
Every time I need to export an asset from Figma in any format, I can successfully export the first but I can’t export any other object afterwards unless I refresh the page. This is becoming a major issue for me as I need to export countless assets for my work on a daily basis and it takes too much time to keep refreshing after every single export, I’ve seen multiple people complaining about the same issue a couple of years ago and they didn’t get a response with a solution either, so I’m raising the issue again.
I’ve been having this issue for months and can’t seem to solve it..
sang_adit
Aug 4, 2025 2:53 AM UTC
i have same issue like this. Do you find any solution yet?
Mona Aymn
Mona AymnAuthor
Aug 4, 2025 8:32 AM UTC
Yes, I’ve struggled with this issue for a long while, then it was automatically solved when the new figma patch was released.
ksn
Aug 4, 2025 6:56 PM UTC
Hey ​@sang_adit - sorry this is causing you problems. I know ​@Mona Aymn mentioned this was resolved after the last patch, but it sounds like that may not be the case for you.
Is the export disruption happening when you use Figma in both the desktop app *and* web browser version?
If it’s just the app, can you let me know what version of the app you are currently running? Are you by chance using the beta version of the app?
Does this happen on all files you try exporting from, or just one? If it’s just one file, can you try duplicating that particular and then try to export it? Does it seem to help? Let me know when you can.
Thanks!!
