Phillip Zannini
Sep 11, 2026 2:12 PM UTC
Figma corrupting when installing on an M5 MacBook Air running Tahoe 26.6.2
I can download the Figma file, open the loader, put Figma in the Applications folder (please note, I’m already doing this), then let it run the install. When the install finishes and I double click the app to launch it from inside the Applications folder, I get the error “The application “Figma.app” can’t be opened.”
I trouble shot this as far as I could, even going into terminal and running a sequence of checks - here’s what that shows. As noted below, I am running Netskope and SentinelOne on a corporate computer.
Initial installation:
spctl --assess --type execute --verbose=4 /Applications/Figma.app
Result: accepted
source=Notarized Developer ID
After launching Figma and allowing its download/update to complete:
Result: rejected
source=no usable signature
codesign --verify --deep --strict --verbose=4 /Applications/Figma.app
Result:
In subcomponent:
/Applications/Figma.app/Contents/Frameworks/Mantle.framework
code object is not signed at all
Additional check:
/Applications/Figma.app/Contents/MacOS/DynamicUniversalApp:
invalid Info.plist (plist or signature have been modified)
The app then fails with:
RBSRequestErrorDomain Code=5
NSPOSIXErrorDomain Code=111
Launchd job spawn failed
Please check whether Netskope, SentinelOne, MDM, proxy/DLP, or Figma’s updater is modifying, quarantining, or incompletely replacing files inside Figma.app during the first-run download/update. Please also test or deploy a known-good fully signed Figma bundle.
Figma is has a VALID developer signature before the launch/install process
Authority=Developer ID Application: Figma, Inc. (T8RA8NE3B7)
Notarization Ticket=stapled
TeamIdentifier=T8RA8NE3B7
Phillip Zannini
Sep 15, 2026 12:26 PM UTC
It was in face the Netskope and/or SentinalOne issue. We turned them off and I was able to install the desktop. Thank you.
adamsmasher
Sep 11, 2026 6:42 PM UTC
Hi, ​@Phillip Zannini. Thanks for your post and for the detailed troubleshooting - it’s very helpful!
I’m wondering if something is trying to check the developer signature mid-update and it invalidates the app before it’s fully updated. Would your IT team allow you to temporarily disable Netskope and SentinelOne while installing/updating? I’m not sure that those are the culprit, but just to rule them out if nothing else.
I’ve also shared with this with the team for review - I will let you know if they have any questions or advice on how to proceed.
Phillip Zannini
Sep 11, 2026 6:55 PM UTC
Hello - I’ve asked the IT team about that, still no reply :/ - working on it though.
adamsmasher
Sep 11, 2026 8:02 PM UTC
A couple questions for you from the team:
  1. Can you download the app fresh from figma.com and try again? This is just to make sure it’s the newest version and not an older one you are updating: https://www.figma.com/downloads/
  2. Are you able to open long enough to go to Help -> Troubleshooting -> Save Debug Info from the top menu? If so, the debug info would be helpful to the team.
Thanks!
Phillip Zannini
Phillip ZanniniAuthorSolution
Jaycee Lewis
Sep 15, 2026 2:46 PM UTC
Thank you ​@Phillip Zannini for taking the time to let us know what worked for you 🙌 — Jaycee
