Jul 7, 2026 4:20 AM UTC
Figma Agent Limit
I thought the figma agent feature does not consume credits during the beta. Is this a bug? or the limit that was said here is something different?
Celine_Solution
Jul 7, 2026 1:19 PM UTC
Hi Kevvv, Celine from the Figma Community Support team here! Thanks for the follow-up and for raising this question.
I was able to see your support case and can confirm that the team is already investigating this with our engineering team.
Based on what you've shared, you're correct that Figma Agent doesn't consume AI credits while it's in beta. From what we've seen so far, the message you're encountering appears to be related to a usage limit on the feature, rather than AI credit consumption. The team is currently investigating exactly what this limit refers to before providing a definitive answer.
In the meantime, please continue the conversation through your existing support case, as that's where the team will share any updates as soon as they have them. Thanks again for your patience while our engineering team looks into this!
Sharing update here for others who may encounter similar issue:
Our team has reviewed this case more closely and wanted to clarify that there are monthly limits for this feature, which helps to manage capacity and costs while it's free in beta. You'll see an in-product message if you hit the monthly limit — it resets each month and won't affect your credit limits for other AI features (How do I access the AI agent beta in Figma Design?).
It looks like this limit may have been prematurely triggered here, please try again, and you should be able to use the feature again.
There will still be limits with very high usage of the feature, but in this case you are now free to continue using the feature again. We apologize again for any confusion this may have caused, and thank you for your patience while we took a closer look.
I’ll go ahead and close the topic here, thank you!
Celine_Solution
