Constantine123123
Aug 29, 2025 8:21 AM UTC
Fallback font problem. Arabic semibold is not redndering.
Hey. When using Arabic, fonts that lack Arabic support fall back to Noto Sans. Today I ran into an issue where the fallback does not render the Semibold weight for Arabic. If I select Noto Sans Arabic directly, everything renders correctly.
    Celine_Solution
    Sep 2, 2025 10:30 AM UTC
    Hi everyone! Thank you for flagging this. I can confirm the issue should now be resolved 🎉
    If you still notice anything off, try re-entering text edit mode or making a quick text change. You can also select all and use the quick action “Recompute Layout in Selection” to refresh the rendering. 🙂
    Andre Nikolaev
    Sep 2, 2025 9:57 AM UTC
    Hi, Constantine! Support replied to my report and solved the issue. Texts display normally now after relaunching figma, at least in my case. Hope your problem will be solved too!
    Constantine123123
    Sep 2, 2025 9:58 AM UTC
    Thanks a lot. Same with me!
    Celine_Solution
