heyhankhowsthebank
Oct 5, 2026 4:18 PM UTC
Export no longer remembers folder choice
Until recently, using the “Export” function in the sidebar opened up a window that showed the last folder used for export. This was quite useful as it allowed for multiple exports to occur into the same folder without needing to dig for the folder each time.
As of last week though, using the “Export” function always defaults the save folder to the Downloads directory instead of the last used export directory.
I can understand defaulting to a directory in lieu of a preference, but can a preference be set within Figma to either default to the last used or default to a specific directory? My workflow benefits greatly from doing multiple exports to a unique directory and this new change has slowed things down quite a bit.
Thanks!
Jaycee Lewis
Oct 5, 2026 10:35 PM UTC
Hey hey ​@heyhankhowsthebank 🤩 Thank you very much. One question — are you using the Desktop app? Or is this happening in both the Desktop app and in the browser? Thanks! — Jaycee
heyhankhowsthebank
Oct 6, 2026 1:56 PM UTC
Hey Jacyee! Yes I’m using the desktop app. I have it set to forward all web activity to the desktop app, so I don’t have an easy way to test if it happens in the web app.
It seems to only default to the Downloads directory if I select multiple items to export. Exporting a single item seems to remember the previously-used directory.
Jaycee Lewis
Oct 6, 2026 3:28 PM UTC
Thanks ​@heyhankhowsthebank 🙌 I added your info with the team working on this. I’ll post back here as soon as I have an update or if the team has a follow up for us. I appreciate YOU! — Jaycee
moji
Oct 15, 2026 7:57 AM UTC
​@Jaycee Lewis I'm having the same issue on the macOS desktop app. Is there any update on when this will be fixed?
Gen Wood
Oct 6, 2026 4:36 PM UTC
I’d first check whether this is happening only in the Figma desktop app or also in the browser, since the behavior could be tied to the native file-save dialog rather than Figma’s export settings.
If it happens in both, I’d check whether the recent update changed the export workflow or removed the last-used-folder preference. If it’s desktop-only, testing after restarting Figma or resetting the app’s local state could help determine whether the saved folder preference is being lost.
heyhankhowsthebank
Oct 6, 2026 4:41 PM UTC
I don’t run into this issue with saving anything else from any other application, so I would be surprised if the problem came from the native file-save dialog. As mentioned, I export from Figma all the time and this only recently started occurring.
I’ve restarted Figma, my computer, and looked for any folder save preferences within Figma, finding none. I don’t know that I have any permissions within my company to reset the app’s local state, though.
It does not occur within the web app, which utilizes the browser’s file-save preferences.
Indigo
Oct 7, 2026 11:42 PM UTC
I’m having the same issue on the desktop app. Restarted it + confirmed on the most up to date version.
Dennis Hallmén
Oct 8, 2026 10:14 AM UTC
I can confirm that desktop now always defaults to downloads folder. Would be great if this was an option you could change. From the browser it just downloads the files like anything else you download through the browser.
Jaco Naude
Oct 11, 2026 4:29 PM UTC
Same issue on desktop app. Thought it was just the one design page or maybe something on my end, but keeps happening on all of my work now, after the previous update.
Jane_SENEOR1
Oct 15, 2026 12:46 PM UTC
I can confirm the same on desktop app. It’s really enoying.
By the way, in web app it reminds the last folder I was exporting to but exports all images into a zip which is also enoying.
Scott McLean
Oct 22, 2026 1:27 PM UTC
Confirming this is also happening in my desktop app as well. Was hoping the recent update would fix this but it’s still happening and really adding a lot of steps to my workflow.
leon.macapagal
Oct 24, 2026 1:12 AM UTC
Confirming this is also happening on my desktop app. This is quite annoying as I have to constantly navigate to the correct folder after each export.
