Anh
Apr 23, 2026 1:19 AM UTC
Export Figma Slides: Stamps result not exported properly on Figma slides
I was using Figma Slides for my design sign off with stakeholders and they love the Stamps feature as it makes sign-off a bit more fun. But my problem is that when I export the slides into PDF, I either lost all the name under the stamps or even worse, some name come across and some don’t :(
It would be good to have the slides retain all the stamps when exported as this is a requirement to our sign off documents in making sure that they are not editable
Apr 23, 2026 9:32 PM UTC
Hi ​@Anh, thanks for flagging this!
I completely understand why you’d want to retain stamped faces when exporting from Figma Slides. May I ask if you consistently name the Stamps interactive section, or do you sometimes leave the automatic title it’s given?
I just tried to reproduce this behavior, and I noticed that stamps are not retained if you don’t manually add a new title to it. But if you add your own title, upon exporting stamps are retained upon export.
Please try this out, and let me know, if you’re still running into the issue or not.
