Andy Gladdis
May 20, 2026 11:25 AM UTC
Error when accessing libraries
When I try to use a library outside of the file that I’m in, I can see the contents of the library but if I try to use anything it shows an error.
E.g. I have a file with some colour tokens and components in that I’m using as library. I have another file which is using the library. When I try to use a colour from the library I see the list of  available token in the library, but when I select one I get an error message saying ‘An error occurred while retrieving the variable’.
If I try to add a component from the library, again I can see the component in the library but when I try to insert an instance I get the error message ‘Unable to load. Something went wrong. Try closing this window and reselecting the component.’
May 21, 2026 4:53 PM UTC
Hi ​@Andy Gladdis, thanks for reaching out!
I completely understand how this must be slowing down your workflow. The good news is that being able to see the library contents but not use them is a pretty telling symptom. Here are the most likely culprits, in order of probability:
1. Unpublished library changes
  • This is the most common cause. Open your source library file, publish any pending updates, then open your working file and accept the incoming updates.
2. Hidden or deleted variables
  • Check that the variable still exists in its collection and that "Hide from publishing" isn't checked in its settings.
3. Permissions/network
  • Less likely given you can browse the library, but worth confirming you have editor access and a stable connection.
The component insert error ('Unable to load') is likely the same root cause. But once the library is re-published and updates are accepted, both issues usually resolve together. Hope this helps, but please let me know if you continue to run into issues!
