Ellipse arc control is a pain
The arc tool currently requires you to use two coordinate systems. The start is an angle, the sweep is a percentage and the thickness (ratio? why is it called ratio?) is a percentage.
Why didn’t you just have a start, an end both in angle measurements (or both percentage being 1% = 3.6deg).
Also why did you decide a percentage for the thickness was a good idea? My guys, we deal in pixels. Is this because an ellipse can be oval shaped? Still think a pixel value would make a consistent experience. Or even better, let the user switch between them.
You’re just making us do maths that we shouldn’t really have a need to do. This should be a very simple set of controls.
