bernardo
Apr 1, 2025 12:42 AM UTC
Drop Shadow effect does not work properly with the new implementation of Remove Background in Figma.
I-ve been using a plugin to remove the background of images directly in Figma. After the last update I found out that an option to Remove Background from the Figma UI was there. Fig 1
But after using the Drop Shadow Effect on an image with the background removed using this method, I found out that it is not correctly reading the transparent pixels. Fig 2
I tested the previous plugin I was using to remove the backgrounds and had no issues applying the Drop Shadow Effect. Fig 3
Fig 1
Fig2
Fig 3
Nellya
Power Member
Apr 1, 2025 9:18 AM UTC
I have the same problem
PDM ENZ
Apr 4, 2025 2:51 PM UTC
i have the same problem! but i’m not using this plugin. i’m having “drop shadow” problem on all png’s…
Pavi
Apr 7, 2025 3:04 AM UTC
I have the same problem it’s so annoying
FIGMA YOU GUYS NEED TO FIX THIS!
it only started recently because when the feature first came out it was fine
PDM ENZ
Apr 7, 2025 7:18 AM UTC
​@Celine_D , ​@Gayani_S
 Can you please check the problem? We haven't been able to work properly for a week, but we have a lot of projects to finish....
P85
Apr 23, 2025 8:40 PM UTC
Is there any indication of when this problem is going to get solved?
Nellya
Power Member
Apr 23, 2025 8:49 PM UTC
