Joshy
Aug 9, 2026 6:17 PM UTC
Different result from the tutor
Hello in the lesson today using auto layout my resultbis different from that of the tutor.
How can i get this correctly
    Nellya
    Power Member
    Aug 9, 2026 7:12 PM UTC
    Hello. You need to use horizontal direction instead of a grid
    Joshy
    JoshyAuthor
    Aug 9, 2026 7:22 PM UTC
    Yes i converted to horizontal but is keeping a uniform frame of all object instead of different frame from each object
    Nellya
    Power Member
    Aug 9, 2026 7:36 PM UTC
    Probably it’s because all your text have the same fixed width. Try to change it to Auto width and apply Hug
    Joshy
    JoshyAuthor
    Aug 9, 2026 8:02 PM UTC
    No they dont. It was a single text that was duplicated and when i use auto layout it widen the space each frame uniformly
    Nellya
    Power Member
    Aug 10, 2026 9:48 AM UTC
    It's how Grid Auto Layout works.
    You can manually apply horizontal Auto Layout instead of using Shift+A to avoid the grid being applied automatically.
    Nellya
    Power Member
    Aug 10, 2026 10:21 AM UTC
    Like this
    Joshy
    JoshyAuthor
    Aug 10, 2026 12:10 PM UTC
    Perfect! The text are now in a different frame size. Thank you so much. I am a beginner so is a bit hard going through it all alone. do you have any resources or information that would help in my learning process?
    Nellya
    Power Member
    Aug 12, 2026 10:27 AM UTC
    Figma has a lot of its own useful learning materials
    Joshy
    JoshyAuthor
    Aug 13, 2026 11:10 AM UTC
    Thank you. I am learning Figma for my Brand Design, how can u narrow it down to what i want to achieve
