morti
Nov 27, 2026 8:59 AM UTC
Dev Mode MCP Server: "Enable desktop MCP server" option is missing (Dev seat, Professional team)
Hello,
I'm trying to enable the Dev Mode MCP desktop server, but the "Enable desktop MCP server" option is missing everywhere in my desktop app, and nothing is listening on http://127.0.0.1:3845/mcp.
What I've already checked:
- Figma desktop app is updated to the latest version (126.11.11)
- I have a Dev seat on a Professional team ("Team project" in my Starter team, plan badge: Professional), I'm the team admin
- The file is open in Dev Mode with nothing selected
- Main menu → Preferences: there is no "Enable Dev Mode MCP Server" item (checked in both Design Mode and Dev Mode)
- Dev Mode right sidebar → MCP section: it only shows a "Clients" row with presets that use the remote server (ChatGPT, etc.) — no enable toggle, no "..." menu on the section header; the "?" icon only links to your documentation
- The "Set up third-party agents" dialog (Clients → "+"): all presets point to the remote server, there is no custom/local server option
- Port check: nothing is listening on 127.0.0.1:3845
Could you please enable the Dev Mode MCP server for my account, as was done for other users in similar cases (e.g. this forum thread: https://forum.figma.com/report-a-problem-6/not-seeing-mcp-server-option-in-figma-desktop-42747), or advise how to enable it?
Account email: (redacted by the moderator due to PII)
Team: morti's Starter team → Team project
Thank you!
Nov 27, 2026 11:51 AM UTC
Hi ​@morti , Celine from the Figma Community Support team here! Thanks for sharing these details.
Access to the desktop MCP server requires a Dev or Full seat on an eligible plan. If your file is located in a separate Starter team, your Professional plan benefits may not apply to that file. However, if your team displays the Pro badge and you have a Dev seat assigned to that same team, you should have access. For more information, you can check our guide: Get started with the Figma MCP server
As mentioned in the other thread you mentioned, the Enable MCP server option is now located within the Dev Mode panel itself rather than in the Preferences menu.
If you're still unable to access this option, please submit a bug report so our Customer Support team can take a closer look at your account, team settings, and seat permissions to investigate further. To do that, go to the Support Hub / Type “Report a bug, Contact a specialist” / Click Start a chat and select Enter and follow the prompts, thank you!
